Oil pressure sending unit location?
Old Feb 25, 2009 | 10:55 AM
Nonni's Avatar
Car: 86 T/A
Engine: ZZ383
Transmission: TH700R4 Raptor
Axle/Gears: 2,7x -> 3.00 or 3.50
I am finishing my project and am not sure where to put the oil pressure sending unit. The engine has Edelbrock Performer RPM intake manifold (it was so obvious on my old 350). Does anybody have a picture of it or some way of guiding me?
thanks, Jon H.
Old Feb 25, 2009 | 12:00 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Oil pressure sending unit location?
On the early year thirdgens it should be screwed into a hole in the top, back side of the block, behind the intake manifold.
On the later years, I think 89-92, they moved it to just above the oil filter. It looks like a black 35mm film cannister.
Old Feb 25, 2009 | 12:10 PM
safemode's Avatar
Car: camaro rs
Engine: 305 tbi and 350 on stand
Transmission: 4spd auto
and on later gens it leaks _all_ the goddamn time. No matter what you do.
But, you should still attempt to try and use teflon tape around the sending unit's threads. Not that it matters as you'll likely start leaking out of the seams of the sending unit itself.
Old Feb 26, 2009 | 06:13 AM
Nonni's Avatar
Car: 86 T/A
Engine: ZZ383
Thanks, I will look near the oil filter. This is a new ZZ383 from Gm Performance so its probably at the same location as 89-92.
Ghettobird52
Jul 5, 2024 11:18 PM
89GTAOz
May 16, 2020 09:31 AM
Infested
May 22, 2018 11:56 PM
355sbcTPI
Aug 19, 2015 04:38 PM
