cars a p.o.s
Old Mar 1, 2009 | 10:53 AM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
cars a p.o.s
went down to start my car and itll run fun, then ill reeve it up and the tach will go to the reeveing rpm, i let off and then car dies. whats goin on here? i instlled an ignition box but it works like it should. im still reading 6 psi on my fuel pressure gauge, so i think its not fuel related. also its got an electric pump if that helps. any ideas? thanks
Old Mar 1, 2009 | 11:31 AM
zipfast's Avatar
Car: 94 9c1 Caprice
Engine: LT1 (3-fity)
Transmission: 4L60E reBUILT
Axle/Gears: 3:08 POSI (out)
Re: cars a p.o.s
Sounds like it's not warmed up yet.
If you push the gas pedel down that releases the
choke and then it can and will stall.
Old Mar 1, 2009 | 05:44 PM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Re: cars a p.o.s
You not giving much info, do you have a carb? F.I.? Usually that sounds like a choke adjustment on a carb. car. Or if it's hot it may be lots of things. If it's injected the pressure is WAY low.
Old Mar 1, 2009 | 06:40 PM
Engine: 355
Re: cars a p.o.s
sorry guys its a carbed car. so it not being warmed up will make it stall? i kinda thought of it to, so dont sound like anything major
Old Mar 2, 2009 | 01:08 PM
Engine: 355
Re: cars a p.o.s
anybody else have problems like im having?
Old Mar 2, 2009 | 01:27 PM
mario82z28's Avatar
Car: 82' z28/03' eddie bauer explorer
Engine: 355-395hp/4.6v8
Transmission: Built 700R4/5speed auto 4x4
Axle/Gears: 3.42LSD/3.73
Re: cars a p.o.s
just like every sbc they need to be warmed up or they will die raise your choke that should help I have to stall mine about 1500 rpm for a couple minuets in the morning and let it warm up after the first warm up she's usually good to go
Old Mar 2, 2009 | 07:29 PM
kcallais's Avatar
Car: 1985 Z28
Axle/Gears: garbage 2.73
Re: cars a p.o.s
I thought you wanted about 10 psi fuel pressure on a carbed motor?
Old Mar 2, 2009 | 07:41 PM
Engine: 355
Re: cars a p.o.s
10 psi would flood the **** outta it, carbed usually run between 5-7psi i thought
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
