Rough idle and possible misfiring under load
Old Mar 1, 2009 | 02:17 PM
86FireBird305's Avatar
Car: 1986 Firebird LG4
Engine: 305 5.0 LG4
Transmission: TH-700R4
Hey guys
So my car starting running really rough on my way to work the other morning. And it sounds like its mis firing when i give it gas. I had similar issue a few months back and i figured out it was the vacuum kick back for the choke.
I replaced that as well as did plugs,wires,cap and rotor and now a few months later its running like crap again. Im really banging my head on this one so any help is good help ha
thanks
Old Mar 1, 2009 | 02:29 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
Re: Rough idle and possible misfiring under load
Has it lost power?
Old Mar 1, 2009 | 02:36 PM
Engine: 305 5.0 LG4
Originally Posted by rough
Has it lost power?
yes it has
Old Mar 1, 2009 | 05:38 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
jack up the front, and tap the cat, if you hear something rattle, that could be your problem.
Old Mar 7, 2009 | 03:41 PM
Engine: 305 5.0 LG4
the cat seems fine...im just wondering if anyone here has ever had a similair problem
Old May 1, 2009 | 04:39 PM
91ZRocker!'s Avatar
Car: 1991 Z-28
I too am having this problem. I took the intake manifold off to reseal it and then when i got the timing readjusted it wouldnt rev up properly under a load.. it will idle a little choppy but will stay at idle 800 rpm. but as soon as i crack the throttle or even try to roll on the throttle it bogs way low, misfires and sometimes dies depending on wether i hold it or not... when it goes back to idle it is fine... I am so stumped at what it could be.. changed the IAC the TPS and MAP and still not fixed... Thinking it might be my fuel pump.. i am gonna pressure check it this weekend.. but yeah if anyone knows anything or has any tips please help...!
Old May 2, 2009 | 12:05 PM
shanewbenson's Avatar
Car: 1992 RS
Engine: 305 TBI
Transmission: IROC 700R4
spray some carb cleaner around the intake manifold and vaccum lines. If its a vaccum leak the car should rev up when you spray the area its leaking from.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
IROCtometal
Sep 2, 2015 02:01 PM
