Plastigage help
Old Mar 1, 2009 | 07:42 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Plastigage help
I am rebuilding an engine and they told me to use plastigage and i got some the red and blue one i wanted to know if i don't check with the plastigage it would affect on the rebuild i am doing.
Old Mar 1, 2009 | 09:45 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Plastigage help
Plastigage confirms machining tolerances. A crankshaft main may be machined .010" under but the block may have inconsistencies which won't be seen without using plastigage. The same goes for the rods.
The thickness of the plastigage, color, depends on the crush specification you're checking. Checking the crank mains, green is the common thickness.
If the crush specifications call for .0025" and the plastigage says you have .0015", you'll need to get undersized bearings. Of course you can only check the crush specifications with a set of bearings.
Old Mar 1, 2009 | 10:05 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: Plastigage help
I ordered stock bearings so i don't know if those would work and the plastigage goes on the connecting rods to the crank or on the main caps of the engine
Old Mar 1, 2009 | 10:25 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Re: Plastigage help
Without knowing the specifications, checking them tells you nothing.
Start with the mains. Install the bearings into the block then place the crank onto the bearings. One main at a time, install a strip of plastigage onto each main and torque the main cap down. Remove the main caps and measure the crush thickness.
If the crank mains check out, do the same thing to each rod bearing.
Anybody can assemble an engine but it takes skill and knowledge to build one properly. My best suggestion is for you to have the bottom end put together by a proper machine or engine building shop. If you screw something up and spin a bearing, it will cost you more than what a shop will charge to put the bottom end together. Then again you may luck out and everything will be close enough to specs.
Old Mar 1, 2009 | 10:28 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: Plastigage help
How much do they charge also the engine is all stock you think it will be ok or should it go to the shop
Old Mar 1, 2009 | 10:58 PM
84Z28406's Avatar
Car: 1984 Camaro Z28 T-tops
Re: Plastigage help
Is plastiguage the prefered method or is a mic set acceptable if you have access to them?
Old Mar 1, 2009 | 11:17 PM
jkris53406's Avatar
Car: 87 Formula, 91 Trans Am
Engine: 355 tpi, 305tpi
Transmission: 700r4, 700r4
Re: Plastigage help
The very first thing you should do is verify you have standard size bearings on both the rods and mains. Remove the bearings and on the back it will say .010 or whatever the oversize may be. If they are stock, there should be nothing.
You may want to head down to your local parts store and pick up a book on small block chevys as well
Old Mar 2, 2009 | 11:45 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Plastigage help
mics are preferred. Plastiguage is very susceptible to user error. I'd pick up a mic if I had it...
Old Mar 2, 2009 | 03:01 PM
84Z28406's Avatar
Re: Plastigage help
Ok, I'll use my mics then. Need to pic up the one that measures inside the circle though, I've only got the outside ones right now.
Old Mar 2, 2009 | 07:18 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Re: Plastigage help
That means you have to install the bearings in the block. Then without the crank in the block, torque down a main cap, with the other half of the bearing in the cap, then measure the distance.
Measure the mains on the crank which should be smaller by the specification tolerances.
Do you know how much clearance you're allowed on the mains and rods yet?
Old Mar 2, 2009 | 11:49 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: Plastigage help
So the plastigage goes on the main bearings and on the connecting rod does it really effect the engine this is my first rebuild that i am doing
Old Mar 3, 2009 | 12:41 AM
84Z28406's Avatar
Re: Plastigage help
I know how to measure the clearances using the mics, but it's good to have it confirmed. As for actual clearances, my Haynes techbook for Chevy V8s says in general it should be 0.001 - 0.002 inch for rods and mains, but that sounds a little tight, so I'm open to suggestions.
Old Mar 3, 2009 | 08:16 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Re: Plastigage help
Plastigage is a thin strip of modeling clay. Once crushed to take the measurement, you wipe it off the crank surface.
Old Mar 3, 2009 | 04:18 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: Plastigage help
Would it affect it if i put the wrong bearings i am probably going to rebuild it again like in a year to do 383
Old Mar 3, 2009 | 08:46 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Re: Plastigage help
If clearance is excessive on the mains you'll have very low or no oil pressure. Excessive on the rods and you'll get a rod knock.
If clearance is too little, you get no oil lubrication to the bearings and you burn up a crank/rod/block.
Old Mar 3, 2009 | 09:36 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: Plastigage help
I will take it to shop instead what cam is good for the tpi i would like a nice rumble to my iroc but wouldn't like to spend alot on only the cam.
Old Mar 3, 2009 | 09:45 PM
BASSETT IROC 85's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 355
Axle/Gears: 7.5 inch 342
Re: Plastigage help
.0025 for me
Old Mar 3, 2009 | 10:36 PM
allred's Avatar
Car: 1986 IROC-Z
Axle/Gears: 10 bolt w/ 3.73's
Re: Plastigage help
the best thing you can do is educate yourself. read everything you can, and maybe take some classes. otherwise you may end up spending a lot of money on a blown engine.
you need to get the block thorougly cleaned.(dont forget to remove cam bearings. magnafluxing is highly reccomended. bore it, torque plate honing recomended. you definetly wanna get your mains line honed. and check the decks for warpage.you may need to shave them. and any parts you are reusing will need to be inspected and may need maching or replacing
clean the block some more. get some pipe cleaners and go through all the holes and oil gallies.(ps use standard oil pump not high volume)
keep it as clean as possible.
make sure to get all the specs you can from the machine shop(amounts of material taken off) for ordering your new parts.
if you want to assymble it yourself get quality measuring tools. measure everything!!!!
oil clearences, endplays, the clearances between the rotating assymbly and the block cam, oil pan, ect ect. deck clearance, piston to valve.
degree your cam!! bending a valve cause your 1 tooth off or cause its the wrong cam isnt fun.
and get a good torque wrench! properly torque every bolt, and use the proper assymbly lubes. and break in oil for flat tabs.
prime your oil pump!
check and check and check timing. detonation is bad.
and do a proper engine break in.
i believe that is everything except the kitchen sink.
if i forgot anything holla
Old Mar 3, 2009 | 10:46 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: Plastigage help
A mechanic is helping me now he has over 10 years building small blocks so i think it will come out okay how much do they charge to bore .030
Old Mar 3, 2009 | 11:00 PM
allred's Avatar
Car: 1986 IROC-Z
Re: Plastigage help
i belive last time i checked it was less than $100 bucks. id call several local machine shops and get quotes.
Old Mar 4, 2009 | 12:17 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Re: Plastigage help
Boring is roughly $10 per hole. To do it properly, they should have the pistons that are going into the engine so they can hone the walls to the proper size. They will also want to know what type of rings will be on the pistons to know what kind of finish to leave on the cylinder walls.
I said it way back near the top. Building an engine properly isn't just assembling a bunch of parts together.
It's amazing how many people don't realize that if you take an engine into a shop to be built properly that you can usually expect it back in about 3 months.
Old Mar 4, 2009 | 05:45 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: Plastigage help
WOuld i need to buy new connecting rods too
Old Mar 4, 2009 | 06:30 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Re: Plastigage help
Not unless the old ones are damaged. New rod bolts would be an investment.
Old Mar 4, 2009 | 11:38 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: Plastigage help
Around how much would it be for a 0.030 bore and new pistons
Old Mar 5, 2009 | 12:20 AM
the zander's Avatar
Car: 86 Camaro IROC-Z
Engine: 305 TPI (retrofit)
Axle/Gears: Crappy stock 10-bolt gears
Re: Plastigage help
Stephen mentioned above that it'll cost you $10/hole for the machine work. As far as the cost of pistons is concerned it depends on what you want, they can cost as little as $10 each and as much as $200 each. For your application stock replacements like the ones below would be adequate.
http://store.summitracing.com/partde...0&autoview=sku
-Z
Old Mar 5, 2009 | 04:33 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: Plastigage help
Do they come with the pins in them and that would give me less mpg cause this is my daily driver
Maverick H1L
May 13, 2011 07:56 PM
hansw3
Jun 30, 2010 02:57 PM
89Mustang5.0
May 17, 2010 11:35 AM
irocnroll89
Jan 17, 2010 02:57 PM
Cambridge205
Aug 14, 2007 07:27 PM
