Starter issues.
Old Mar 5, 2009 | 03:31 PM
Ivelostcontact's Avatar
Car: 1984 z28 H.O.
Engine: 305 H.O.
Axle/Gears: 10 bolt
Starter issues.
The car is an 84 z28, 5 speed. It all of a sudden stopped starting the other day. I can push start it and jump it from the solenoid. When I turn the key to the start position all the guages come on, temp goes to the right, volts come up, the works. Everything electrical on the interior works. What could be causing it to not start. It has three leads, the batt to the center terminal, another smaller lead that runs to the center terminal and a lead to the S terminal. Could it be the ignition switch?
Old Mar 5, 2009 | 03:43 PM
blackandgoldl69's Avatar
Car: 1984 camaro z28
Engine: L69 H.O
Re: Starter issues.
do you hear a clicking noise when trying to turn the car over? also have u checked all of the connections to make sure they are tight also check your battery and see if it needs to be charged
Old Mar 5, 2009 | 03:45 PM
Car: 1984 z28 H.O.
Engine: 305 H.O.
Axle/Gears: 10 bolt
Re: Starter issues.
I hear nothing but the click from my clutch and the little buzzer sound from when I have it in the turn over position. The leads are wrench tight.
Old Mar 5, 2009 | 04:21 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Check the voltage getting to the starter through the small wire when the ignition is in the start condition. If it is zero, you've got a problem somewhere in the line, either wiring, connector(s), ignition switch, neutral/clutch safety switch.
If you get some voltage but it's low, same train. I had that issue and solved it by installing a remote solenoid (really just a high capacity relay).
Old Mar 5, 2009 | 04:29 PM
Car: 1984 z28 H.O.
Engine: 305 H.O.
Axle/Gears: 10 bolt
Re: Starter issues.
ok, i'll check that out tomorrow and let you know what's up.
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
