flippen summit ignition box
Old Mar 5, 2009 | 06:52 PM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
ok i just bought a new summit street and strip ignition box. i start the car and have my gf run it threw rpm levels, and the car stalls. after pissn moaning and gronning i noticed that the ignition box is shutting off when ever it wants. the led will blink, then go solid, and shut off, taking car down with it. anybody know what causes that? i checked wires and everything. i called summit and they said its a bad box. anybody gimme any insite?
Old Mar 5, 2009 | 06:53 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
It's a bad box.
Old Mar 5, 2009 | 08:04 PM
Engine: 355
Re: flippen summit ignition box
Originally Posted by five7kid
It's a bad box.
dam i wonder how that happened. u 100 percent sure?
Old Mar 5, 2009 | 08:31 PM
five7kid's Avatar
No, but they probably know something.
Search "summit box" and member name mw66nova.
Old Mar 5, 2009 | 08:41 PM
Engine: 355
pk it was a brand new box too. now gotta rip dang thing out
Old Mar 6, 2009 | 08:35 AM
Engine: 355
talked to summit they said that it can either be a bad pickup coil or im getting an interference from my power wires touching the magnetic pickup wires. that true? anybody have that problem?
Old Mar 6, 2009 | 09:41 AM
8urv8's Avatar
Car: 1992 Camaro RS
Engine: 3.1L V6 w/.425" cam (Int. & Exh.)
Axle/Gears: Stock
a voltage surge could be the problem too. Have you checked your voltage regulator? It (the box) could be shutting down because of overload on the internals. could be over loading the chips or capacitors inside.
Old Mar 6, 2009 | 09:55 AM
Engine: 355
ya i just looked at the instructions and it says to route the trigger and magnetic wires seperate. i ran em all together. DOH! so hopen thats my issue
Old Mar 6, 2009 | 10:04 AM
8urv8's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
yep, always read the destructions.
Old Mar 6, 2009 | 10:07 AM
8urv8's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
BTW I hope it didn't cause any damage to it by doing that!
Old Mar 6, 2009 | 10:21 AM
Engine: 355
i hope it dont either. im thinking thats my problem what do u think lol
Old Mar 6, 2009 | 10:25 AM
8urv8's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
prolly. I've got an MSD 6AL box on my 3.1L V6 and I love it. It works great, but I read the instructions. LOL!!!!
Old Mar 6, 2009 | 10:49 AM
Engine: 355
lol ya i wanna get it done its nice out
Old Mar 6, 2009 | 10:51 AM
8urv8's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
yeah, It's nice down here in jawja today. (really bad slang for Georgia. lol)
this stupid thing won't even let me type r edneck without puting a space or sumthin in the word! geeeeezzz!
Old Mar 6, 2009 | 04:49 PM
Engine: 355
now i seperated the wires and im still gettin a slight miss at higher rpms, what would cause that? and my idel is alot higher than it was at with the stock ignition. do i gotta reset all them points again with a bigger ignition
Old Mar 7, 2009 | 09:52 AM
8urv8's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
yeah, if you are getting a miss at any RPM's check your points and see if they are out of wack. are you running a carb or throttle body?
Old Mar 7, 2009 | 01:55 PM
Engine: 355
i have a carb car. i replaced the cap rotor and coil with hypertech, also taylor wires, and new acdelco plugs and still gettin a miss at 2500rpm when reeving, whats up with it now?
Old Mar 8, 2009 | 03:03 PM
Engine: 355
anybody?
Old Mar 9, 2009 | 11:04 AM
8urv8's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
well, I'm running out of ideas. hmmmmm, try checking all your spark plugs' gap & check and see if you have a voltage leak from one of your plug wires. I do know that between 2000 and 3500 RPM is when your ignition produces it peak voltage. it could be a leak to the block or some other peice of grounded metal. Idk.
Old Mar 9, 2009 | 08:03 PM
Engine: 355
ya im outta ideas to. i think im gna twist the wires from magnetic pickup together, and do an engine to chassis ground
Old Mar 9, 2009 | 08:25 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Well im not really familiar with the summit ignition box but if your desperate whet the heck ill take a stab at it lol. Can you describe this miss alittle better? Does it happen under load at any other lower RPM? Is it rhythmic or more random like a stumble? One thing ide check is to see if the ignition wires are routed too close together. The can induce a missfire in nearby plug wires.
Old Mar 9, 2009 | 08:38 PM
Engine: 355
its more like a hesitaion miss then anything. i have a plug wire resting on a valve cover, would that do anything> all my wires are seperated by the wire seperator things... it only misses when reeving it at 2500 rpm. lower and idle has none.
Old Mar 9, 2009 | 08:46 PM
Not likely resting agains the valve cover would do anything. I wonder about the spark advance though. Try this with the car running take a dial back timing light if you have one and measure your base ignition timing as well as the timing with advance at higher RPMs. I wonder if its just being advanced too far or just not far enough.
Old Mar 9, 2009 | 08:55 PM
Engine: 355
so if i have to much timing or not enough itll do that? my gfs dads buiddy adjusted iot before i got the box by ear, didnt use a timing light. so what should my timings be at?
Old Mar 9, 2009 | 09:10 PM
Yea timing can cause a whole lot of issues. I like to set my timing at about 12 degrees. Its one of thoes things it varys from car to car everyones got a different oppinion on the matter but ide start at like 12 degrees and adjust from there see where it feels best without pinging.
Old Mar 9, 2009 | 09:16 PM
Engine: 355
k im gna try that then. its a start
Old Mar 10, 2009 | 10:21 AM
8urv8's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
i just thought of something else. I wander if you could possibly have a bad dist. cap or rotor? you could have a hole in the cap causing an arc. just a thought.
Old Mar 10, 2009 | 05:11 PM
Engine: 355
ya i already installed a new hypertech coil cap and rotor does the same thing. im lost
Old Mar 11, 2009 | 10:23 AM
8urv8's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
, let me think....ok, i thought. i don't know! i'm officially out of ideas!
Old Mar 11, 2009 | 11:04 AM
Engine: 355
GTAman
Jul 3, 2024 07:29 PM
New2Chevy
Sep 28, 2015 12:35 AM
TrevinE
Sep 14, 2015 03:20 PM
roysatikas
Sep 7, 2015 08:08 PM
Jlanz55
Sep 6, 2015 02:35 PM
