temp problem
Old Mar 6, 2009 | 12:38 AM
johnny89345's Avatar
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
temp problem
so today i drove my car for about 20min on the highway and noticed my temp was 110 degrees but the heat was blasting on me then i pulled over waited a few min and the temp went up to normal then once i started driving withing 5 min went back down to 100
Old Mar 6, 2009 | 02:43 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Re: temp problem
just a fair warning..... our cars run at 200* normally
fan switch stock operates at 210* i believe, nothing to worry about lol youre not driving a 4 banger, 4 more cylinders equal 4 more detonations
not an issue lol
Old Mar 6, 2009 | 01:31 PM
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
Re: temp problem
so what do you thinks wrong when i turn the key to start the needle jumps up and at idle it reaches normal temp but emidiately drop withing 5 min of driving so do you think its the coolant temp sensor or maybe the guage is taking a ****
Old Mar 6, 2009 | 01:35 PM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
Re: temp problem
sounds like my car. its the extra air moving over the engine/radiator cooling it down, doesn't sound like a problem to me
Old Mar 6, 2009 | 01:56 PM
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
Re: temp problem
it never did this ber\fore cmon 100 degrees at cruising speed
Old Mar 7, 2009 | 12:43 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Re: temp problem
its just our cars your gauges are what? 20 years old at this point i hookup up a tech 1 on mine and the cts was reading to them ecm at 210* closed loop but the gauge was pegged
i installed an after market gauge the goes into the cts spot it reads dead on 200* when idling, then 180* at cruisin speeds.
the temp change is normal
Old Mar 7, 2009 | 01:18 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Canadian car? As in, 100 degrees C?
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
GTAman
Sep 21, 2015 09:57 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
