ROARING REAREND ?????'S
Old Mar 7, 2009 | 07:59 PM
dickeymoore's Avatar
I'm thinking of getting a 2001 Camaro SS with 65K miles on it and the owner says that the rear end is ROARING,I think I read somewhere that these rearends roar a lot,is this normal if so or not what is the problem with them and the fix?THANKS
Old Mar 7, 2009 | 08:17 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: ROARING REAREND ?????'S
you should ask about that on a 4th gen site... but as a 4th gen owner myself no the rearend shouldnt be "roaring" that isnt normal... normally a sign of damage or inproper setup due to previous damage... notice the damage comes up alot however it shouldnt be to expensive to fix properly... but it means it has been beaten as these rearend tend to hold up to quite a pounding
Old Mar 7, 2009 | 08:48 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
if the price is good, go for it. But assume the rear will have to be replaced or repaired.
Old Mar 8, 2009 | 12:12 AM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
I have a rear end from a 2000 SS. It howls when I'm cruising. Goes away on throttle lift, and goes away when I'm accelerating. I'd always assumed it was abused in it's former life behind a cammed LS1....
Worst case, you can find these rear ends for anywhere from $200 - $400.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
UltRoadWarrior9
Apr 28, 2020 10:39 PM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
WickedBowtie
Sep 11, 2015 11:24 PM
86White_T/A305
Aug 17, 2015 12:16 AM
