wind shield wiper motor on the rs
Old Mar 8, 2009 | 10:41 PM
eschevyrda's Avatar
Car: 89camaro rs
Engine: 350tbi (needs carb!)
Axle/Gears: 32x in process
i tried searching but there is no direct answer to this question
n i posted in here since i have a tbi and its a rs
well i went to get the car on the road again , after storage from winter.
i realized that the windshield wipers work about 2 -3 inches up and then go bak to regular park position .
they only activate at full speed.
i looked for bent arms and found nothing out of the ordinary.
i also swapped the wiper motor with another used one and still have the same problem.(can i be that unlucky that both me be faulty)
i looked in the motors and see nothing wrong with them.
what could it be?
i need the help guys thank you
p.s. what pisses me off is that they worked before it was put to storage and i remember because the last day the car was used was during a minor snow storm.
Old Mar 8, 2009 | 11:37 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: wind shield wiper motor on the rs
Moved from TBI board.
Old Mar 8, 2009 | 11:46 PM
1piece@atime's Avatar
Car: 86 T/A
Engine: 5.0 TPI
It's probably the wiper control module ... although I don't remember anyone else describing the same problem you have. And you changed the motor and still have the same problem. Each of your motors had a module attached?(the black plastic part with the electronics inside) So I find it hard to believe they're both doing the same thing. Ok, This is like thinking outloud... I can't help you sorry
Old Mar 9, 2009 | 04:06 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
I'd be leaning more towards the wiper switch itself. There are tests you can run that are listed in a Helm's manual and probably others as well.
Old Mar 9, 2009 | 07:39 AM
eschevyrda's Avatar
Car: 89camaro rs
any input is helpful guys,
im going to see if i can take a video of this and post on here .
Old Mar 9, 2009 | 12:08 PM
eschevyrda's Avatar
Car: 89camaro rs
Old Mar 9, 2009 | 12:59 PM
trumps2000's Avatar
Car: 1985 Z28
Transmission: T-5 5 Spd
Axle/Gears: Built 10bolt w/3.73s
That happened to me, in the rain no less. Check the linkage at the wiper motor, i found the bolt was spinning when it wasn't supposed to be. I believe all I needed to was tighten the bolt.
Old Mar 9, 2009 | 04:59 PM
eschevyrda's Avatar
Car: 89camaro rs
i checked yesterday the bolts and the arms were tight, but i couldve missed something
im going to check again,
like you said non the less it is raining as you can see in the video ,
you also peeped how the the washer fluid isn't working either , can it be related?
im going to check tomorrow and maybe make another video , all depends if it still raining or not
Old Mar 9, 2009 | 06:33 PM
trumps2000's Avatar
Car: 1985 Z28
Watch the bolt inside the cowl as its turning, thats how I figured it out. I think it was jammed.
iyou also peeped how the the washer fluid isn't working either , can it be related?
Nah seperate problem. Its pretty common, mine doesn't work either. Take the washer pump out and with a hose on the suction side and the other end in a galss of water apply 12V. It should come on and start squirting water.
The other problem is, when the pump is off the fluid runs back into the resevoir and the pump has to reprime. They say to run the hose underneath the booster, so it doesn't drain. Didn't work for me though. I'm going to replace it with a washer tank with the pump built into the tank.
Old Mar 9, 2009 | 10:08 PM
eschevyrda's Avatar
Car: 89camaro rs
good looking on the info im going to try this tomorrow and see if ican get this working by the end of the week ,
this is as worse if not the same as riding my motorcycle ,
lol got me looking at the sky and watching the weather channel lol
Old Mar 10, 2009 | 09:29 AM
trumps2000's Avatar
Car: 1985 Z28
Burnouts are fun in the rain, but not seeing where you're going ... not so much.
Old Mar 10, 2009 | 05:00 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Burnouts in the rain are for underpowered fwd pieces of crap.
Same goes for burnouts in gravel.
Old Mar 10, 2009 | 10:28 PM
trumps2000's Avatar
Car: 1985 Z28
LOL, I guess I meant fish tails. I definitely don't need rain to do a burnout.
siberian3rdgen
Interior Parts Wanted
Aug 31, 2015 09:37 PM
Randomtask2
Aug 26, 2015 03:34 PM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:18 PM
kyle5647
Aug 15, 2015 11:56 PM
slade5612
Aug 11, 2015 07:19 PM
