What makes an LS7 lifter superior to a 'normal' lifter?
Old Mar 8, 2009 | 10:56 PM
neat's Avatar
Car: 1991 Corvette
Engine: Bottle fed L98
Transmission: ZF 6 speed
Axle/Gears: D44 IRS/3.92
I'm curious what the differences are between an LS7 lifter and a 'normal' lifter. What steps are needed if you use an LS7 lifter? Is it a direct swap? Do you need different length push rods? What are the benefits?
Thanks!
Old Mar 8, 2009 | 11:05 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
Re: What makes an LS7 lifter superior to a 'normal' lifter?
I'd say better clearances for higher rpm operation. Most hydraulic lifters have the oil blow by the piston in them which collapses the lifter and the motor then has basically less of a cam at 6500+rpm.
Old Mar 9, 2009 | 01:31 AM
neat's Avatar
Car: 1991 Corvette
So below 6500 there is no benefit?
Old Mar 9, 2009 | 11:34 AM
Shinobi'sZ's Avatar
When I rebuilt my 01 LS6 motor I ordered some of the "new" LS7 lifters thinking what the hell for $120 why not. What I found is that they were identical to my LS6 lifter. Apparently there was a change to the LSx lifters away from the LS6/1 lifter....if you look at the oiling hole it looks like the old LS6 lifter. They are fine lifters. I ran mine up to 1000bhp @ 6500rpms with the rev limiter set to 6750. No problems ever with the old or new...so far.
sweet_87_iroc
Sep 25, 2015 10:01 PM
Mickeyruder
Sep 2, 2015 02:45 PM
Cameeeero
Aug 20, 2015 03:06 AM
86White_T/A305
Aug 17, 2015 12:16 AM
