305 TBI Won't Turn Over
Old Mar 15, 2009 | 08:08 PM
novafirebirdguy's Avatar
Car: 90 Formula WS6, 86 Sport Coupe
Engine: 305 TBI, 2.8 MPFI
Transmission: 700r4, 700r4w/vette servos
Axle/Gears: 2.73 Open, 3.42 Open
Hi guys, I just replaced the starter in my 90 Firebird Formula and she still won't turn over. The battery is brand new, neutral safety switch is fine. The starter isn't getting any voltage. What else could it be? I assume it would have to be some sort of switch or electrical short, but I'm not too good with wiring and I'm used to working on much older cars. Also, the voltmeter in my car says the battery has less than 9 volts but I'm getting 12.47v at the battery, could I need cables? The cables seem to be fine though.
Thanks in advance
Alex
Old Mar 15, 2009 | 08:15 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: 305 TBI Won't Turn Over
you should check for a bad Ground to the block and the firewall
xkingcodex
Feb 12, 2020 07:43 PM
Derick15
Sep 17, 2016 05:28 PM
apo_bailon15
Mar 28, 2016 05:20 AM
Jae992
Aug 27, 2015 09:07 AM
