knocking?
Old Mar 16, 2009 | 08:52 PM
rock861261's Avatar
knocking?
i have a 91 camaro 350 and just bought the moates datalogger when ever i revv up to i get 2 knocks and it retards me i just did a plug change all the plugs looked good all tan all gapped good i also changed my fuel filter still nothing over 3500 rpms i checked timing looks good 6*bdtc the only thing i can think is maybe i have to up the octane im only running 87 any ideas would be help ful
Old Mar 16, 2009 | 09:52 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: knocking?
87? It's a performance car, not a Camry. :-) Spring for the 20c a gallon.
Old Mar 16, 2009 | 10:10 PM
rock861261's Avatar
Re: knocking?
lol ok it just never did it before with the 87 im going to put a couple gallons of 100octane to see if its really pinging or if its a bad knock sensor
Old Mar 17, 2009 | 01:16 AM
birdtojag's Avatar
Car: 87 Firebird, 90 bird coming soon
Engine: 355 Chevy Vortec Heads TPI, LT1 inj
Axle/Gears: 2.77 posi 9-bolt
Re: knocking?
Should be fine with 91 or 92 octane, which ever your area has.
Old Mar 17, 2009 | 10:35 PM
rock861261's Avatar
Re: knocking?
Ok I put same 100 octane in same thing runs a little better but samething
Old Mar 18, 2009 | 12:38 AM
birdtojag's Avatar
Re: knocking?
How many miles on the engine? I'm thinking it might be piston slap. This can happen if the engine has high milage and is worn out a bit.
Old Mar 18, 2009 | 02:48 AM
rock861261's Avatar
Re: knocking?
Could be 149000 miles but how can I get rid of it? I get passed by civics =(
Old Mar 18, 2009 | 07:45 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: knocking?
Unscrew the sensor from the block. Wrap the threads with way too much teflon tape, then reinstall it, but don't tighten it any more than just enough to keep it from falling out. This will desensitize it. Teflon goop in a bottle won't do, it has to be tape.
RedLeader289
May 28, 2019 01:47 PM
bigjay89gta
Oct 15, 2015 08:04 AM
efiguy
Sep 27, 2015 01:30 PM
spartanreaper
Sep 25, 2015 07:22 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
