new intake and carb, no kickdown
Old Mar 17, 2009 | 12:46 AM
84 maro's Avatar
Car: 84 Camaro Sports Coupe
Engine: Carb'd 5.7L 350 W/ Funct. SS Hood
Axle/Gears: Stock for now
i have a 350 crate motor still stock and i put a performer eps intake and 600 carb on it, we got it running and took it for a spin i realized my kickdown wasn't working so we adjusted the cable twice until it would kick down but it shifted into 3rd at 40 mph instead of around 60 where it use to and wont kick down on the highway, has anyone had this problem? i dont have much room for adjustment on the cable now but i beleive the q-jet before had a throttle positioning sensor on it that isnt on the new carb, if that is indeed what it is would that be the cause and what could fix it?
Old Mar 17, 2009 | 07:57 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: new intake and carb, no kickdown
1) which carb?, and 2) did you use a geometry corrector bracket?
Old Mar 17, 2009 | 08:25 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
It says 700R-4 transmission by your avatar. 700R's don't have a kick-down, they have a TV cable. The transmission will be damaged if run without the TV cable set up properly so that the fluid pressure matches the engine loading.
Old Mar 17, 2009 | 10:39 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
I was assuming the OP really meant the TV cable.
Old Mar 17, 2009 | 04:08 PM
1986bluez28's Avatar
Car: 1986 Z28
Engine: 305 for Now
Summit has the bracket for 19.00 bucks that hooks to the carb if its a holley.
Old Mar 17, 2009 | 08:14 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
For Holley, you'll need both TCI-376705 $27.88 AND TCI-376715 $35.95For Carter/Edelbrock, it's TCI-376700 $26.88 AND TCI-376710 $42.88
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
DJanes97
Sep 1, 2015 02:55 PM
theurge
Aug 21, 2015 12:46 PM
86IROC112
Aug 17, 2015 02:00 PM
