Sporadic Oil Pressure
Old Mar 17, 2009 | 11:56 PM
novafirebirdguy's Avatar
Car: 90 Formula WS6, 86 Sport Coupe
Engine: 305 TBI, 2.8 MPFI
Transmission: 700r4, 700r4w/vette servos
Axle/Gears: 2.73 Open, 3.42 Open
Hello all, this is my first third gen ever and I'm used to working on older cars so I'll probably need ya a lot. I've got a 1990 Firebird Formula and among it's several problems the oil pressure is very sporadic (according to the gauge anyway). I know it needs a serpentine belt and either the alternator or P/S pump is squeaking. Anyway, the oil psi is on the higher side of the guage and its pretty much constantly jumping 5-10 psi. I'm only 15 so my knowledge is severely limited and I haven't a clue what it could be. If anybody has any tips as to what it could be I would greatly apreciate it.
Alex
Old Mar 18, 2009 | 07:34 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Sporadic Oil Pressure
I think you have a sporadic ground for the gauge.
Old Mar 18, 2009 | 08:04 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
it seems G.M.s oil press. sensor is not the most reliable . it's located above oil filter . not too bad to replace , be careful with old brittle plastic on connector . bad sensor is the cause of most oil press. indicator problems . good luck .
Old Mar 18, 2009 | 08:13 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Yes, it can be the sender, located behind the intake manifold, on the driver's side.
Old Mar 18, 2009 | 03:24 PM
Alright one less thing to worry about! Thanks for the info.
Old Mar 19, 2009 | 11:35 PM
Dennis-Z28's Avatar
Car: 1991 Z28 Convertible
Transmission: 5-speed
Axle/Gears: 10 bolt, 3.08
Is this sensor above the oil level after the car is off and sat for a bit? Or is oil going to pour out?
83 Crossfire TA
Jan 3, 2016 01:26 PM
angel2794
Sep 8, 2015 06:22 PM
Strick1
Sep 4, 2015 07:11 AM
solocus
Sep 2, 2015 12:14 PM
