Blower motor stays on. Why?
Old Mar 21, 2009 | 03:18 PM
pontiaccraze's Avatar
Hey guys. I got a new blower motor a while back and it worked fine. I used the fan speed selector in the car to choose from hi to low or to turn off you know. Then one morning when it was real cold I had the blower on hi and the controls inside set to heat and the lower control set to come out the bottom. Then when I went to slide the control to turn it off it just stayed on and the blower ran on high. So had to manually pull the plug on the blower itself to turn off. What could that be. I messed with the heater controls inside and unplugged each one and plugged them back in but the blower just blows on high. What could that be guys? I would like to fix this before I go sell the car at a car show. Its on my 82 trans am.
Old Mar 21, 2009 | 10:06 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: Blower motor stays on. Why?
I'd say your dash switch is bad. There's really nothing else in the path.
Old Mar 22, 2009 | 01:13 AM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
when the blower motor is running with the key off, give the high speed blower relay a tap or 2 with a screw driver.
if the blower shuts off the relay is sticking.
Old Mar 22, 2009 | 08:53 AM
That was it! The relay was just sticking. thanks.
Frozer!!!
Jan 19, 2024 04:55 PM
Fronzizzle
Mar 18, 2019 08:29 PM
mhatfield 14
Aug 15, 2015 10:47 AM
Street Lethal
Aug 13, 2015 08:28 PM
stalkier
Aug 13, 2015 12:59 PM
