Ls1 head in a Lt1
Old Mar 24, 2009 | 12:06 AM
Dany89's Avatar
Ls1 head in a Lt1
Will an Ls1 heads fit the 350 Lt1???
Old Mar 24, 2009 | 12:57 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: Ls1 head in a Lt1
Short answer - no.
Old Mar 24, 2009 | 10:34 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Longer answer: World or Dart, I forget which, makes a special block just for this. But without that new block, No.
Old Mar 24, 2009 | 11:35 PM
Air_Adam's Avatar
Thats a gen 1 based block though, not a Gen II (LT1) based block. That block, IMO, really does seem like the solution to a problem no one really had. An LSX swap will, in the end, probably cost the same, but the LSx is a better design with a MUCH stronger bottom end.
LSx heads are totally different in every way than Gen 1 or Gen II heads - only similarities are that each head has 8 valves and the bore centers are 4.40" apart. Thats it.
Old Mar 25, 2009 | 09:08 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
When you put it that way, I'd hafta agree.
Old Mar 27, 2009 | 12:27 AM
Air_Adam's Avatar
Sorry if I seem like a d**k in my reply lol... was just my 0.02
I just don't see the point of spending that much on the block alone just so one can use LS heads, when an LS block will cost less and has all the benefits of the superior LS design. The Gen 1 is a good engine, but the LS is superior in every way. Except exhaust note lol.
Old Mar 27, 2009 | 09:17 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
No need to defend yourself, you didn't seem like a ****. I just hadn't considered it from that angle. All the 4th gen F-cars that came with the LT1 can obviously be easily converted to the Lsx. It's like a no-brainer. Same mileage, more power...
Old Mar 28, 2009 | 09:16 AM
Vader's Avatar
Originally Posted by Air_Adam
... The Gen 1 is a good engine, but the LS is superior in every way.
Except the oil pump. Even that can be resolved. Beyond that, you're right. The LS-Series is a superior case, and the slightly weaker head attachment is apparently not a problem for sealing.
Old Mar 28, 2009 | 07:11 PM
Air_Adam's Avatar
LT1 cars like mine (97 Z28 T56) still need most of the same work that a 3rdgen would need to install an LSx. Still need to change out the motor mounts and probably modify/replace the K-member as well. All the A/C is different. Exhaust (depending on year of LT1). Alot of the driveline stuff, as smilar as it is, is different enough to require changing parts too (clutch related and bellhousing for example).
The one major difference, is that the LT1 cars can use all the parts from a donor LS1 car. The 3rdgen guys will have to visit the aftermarket for alot of components. In the end though, I would definitely say an LSx swap is a better route to go than trying to make LSx heads work on a Gen 1 or Gen 2 just because its a little easier to make the block fit in the chassis lol.
I stil think the exhaust note of an LT1 can't be topped by ANYTHING streetable you'll find in another modern day muscle car. I may be biased though lol.
Old Mar 28, 2009 | 08:05 PM
Tommychu's Avatar
At work we have 6 LQ9 service trucks, and the oldest one has an open exhaust, another one ended up with a generic muffler similar to the hooker one on my car (all of them have ridiculous engine hours due to the compressor mounted to the engine which keeps it revving at 2-3000 rpm and our jobs usually last about 2 hours, everything wears out stupid fast including exhausts. the stock mufflers basically turn into supersize resonators). the former sounds almost disgusting but the latter has quite the lovely note.
And that's just incidental, if you're actually trying to make it sound good better results are almost guaranteed.
midge54
Dec 27, 2019 04:14 PM
deracer
Apr 11, 2016 12:04 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
sreZ28
Aug 14, 2015 07:48 PM
