1988 350 tpi worn out!!! dont know what engine block i can use!
Old Mar 24, 2009 | 07:53 PM
oldrtyblg23's Avatar
can anyone help i need to get a motor and want to keep my tpi but want to get a longblock to replace the worn out motor wut do i need?
Old Mar 25, 2009 | 01:41 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: 1988 350 tpi worn out!!! dont know what engine block i can use!
Any later model '87+ longblock or shortblock with the roller cam setup and one piece rear main seal will be a direct drop in.
Old Mar 26, 2009 | 07:05 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Your block is "worn out"? How so? How do you know?
The chances of finding a used long block to exactly replace your performance-wise is slim.
However, you could rebuild your current engine, if that's what it needs. Or, get a rebuilt replacement. http://www.rebuilt-auto-engines.com/...04109386401.3b Be sure to tell them what you've got, and that you want 083 heads and roller lifter cam. Two of my brothers have bought a rebuilt from them, still running strong after 4 and 1-1/2 years.
theshackle
Mar 5, 2017 06:37 PM
lakeffect2
Aug 23, 2015 08:44 AM
wruiz
Aug 13, 2015 09:07 PM
gta power
Aug 13, 2015 06:15 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
