Starter Problems
Old Mar 25, 2009 | 09:13 PM
84 camaro z28's Avatar
Car: 84 camaro z28
Engine: 5.7 carbed
Transmission: turbo 350
Starter Problems
I just recently rebuilt a 383 and putting the starter on it doesnt get close enough to the flywheel, it catches the edges of the teeth but thats its. I was wandering what to do about this, i heard that mini starters are adjustable but i wanted some opionions. Anything would be great, I used 2 differnt types of nose starters and ones way to close and the others too far away. The one thats too close takes more then a whole shimkit to fit anywhere near.
Old Mar 26, 2009 | 07:08 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
What block, starter, and flexplate do you have?
Old Mar 27, 2009 | 01:20 PM
Car: 84 camaro z28
Engine: 5.7 carbed
Re: Starter Problems
i have a 80's ish 350 block with a 10 tooth starter not sure of the ratio with a 168 externally balanced flex plate.
Old Mar 28, 2009 | 10:36 AM
Car: 84 camaro z28
Engine: 5.7 carbed
I've called summit, napa, arnolds, and car quest and none of them have ever heard of this. Summit thinks its a egg shaped fly wheel but it worked just fine before the build. Ive been told that i can try grinding the casing on the starter to make is closer to the block so I think im going to try this. Any thoughts on this?
Spyder_TheGamer
Dec 25, 2015 05:07 PM
5spdcamaro
Aug 28, 2015 02:12 AM
92camaroJoe
Aug 13, 2015 06:07 AM
milk
Aug 10, 2015 06:26 PM
