Where does this vaccum line go? 89 TPI
Old Mar 27, 2009 | 10:20 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
I just recently completed my engine swap, 305 to 350, the problem is I have a vaccum line that I have no idea where it goes. It t-s off of the vaccum line for the HVAC system where it goes to the vaccum port on the rear of the plenium. It's about 4 feet long and has another T on it. I can't figure out what it's suppose to go to but its quite long and could reach just about anywhere in the engine bay. So basically I have 2 vaccum connections that I don't know where they go any ideas? I'll try to get some pic's up tommorrow... I'm open to any ideas if you think you might know where it goes.. thanks!
Old Mar 27, 2009 | 10:57 PM
boldguy's Avatar
Car: 1992 Z28
Transmission: World Class T-5 5speed manual Trans
Axle/Gears: STOCK G92 performance 3.42
Re: Where does this vaccum line go? 89 TPI
Cruise control vacuum supply perhaps?
If you are standing on the passenger side there should be 3 vacuum ports (2 on a MAF car i believe, feel free to correct me ) First one from left to right is for MAP sensor, second one is for Fuel pressure regulator, and the third is for Cruise control... I think... 80% sure
Old Mar 28, 2009 | 10:15 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Old Mar 28, 2009 | 10:54 AM
89RsPower!'s Avatar
So the cruise vac t-'s off of the hvac vac supply? That was my first thought as well but I can't figure out where the missing port is.. can't find any on the servo or underneath.. Well thanks for the suggestion I'll have to look at it again and see what I can find..
LT1Formula
20
Nov 14, 2015 12:02 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
Sanjay
Aug 12, 2015 03:41 PM
