Engine rattling question
Old Mar 26, 2009 | 08:19 AM
bummys_hotrod's Avatar
Car: 84 Z28
Engine: 383
Axle/Gears: 7.5 3.73
I started hearing a rattling from my engine last night. I thought mabye it was a loose rocker so I proceeded to take the valve covers off and check but when i was taking off the spark plug wires on of the wires came out of the boot rather easy. I just rebuilt the motor to a 383 and got about 500 easy miles on it. So i have been taking the spark plug wires on and off rather frequently checking stuff. After the wire fell apart I took all the wires off and cranked the engine and there was to knocking anymore. Also when the car was running the rattling would not increase with RPM's. It mainly did it at low RPM's. My question is could a loose spark plug wire cause the engine to knock. I did notice that it was running a really low RPM when at Idle and shaking alot.
Old Mar 26, 2009 | 07:10 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
It's possible.
Get all the wires and plugs up to snuff and see if it quiets down.
Old Mar 27, 2009 | 01:55 PM
Car: 84 Z28
Engine: 383
Re: Engine rattling question
well i got the new spark plug wires on. Still rattling sound coming from the front of the engine. It started to whistle a little to. Could these be a spun bearing. I only have about 500 miles on the engine. I have good oil pressure. The only other thing i can think it would be is the timing chain hitting the cover. I didnt put a new one on when i rebuilt it. Stupid move i guess. Whats the easiest way to know if its a bearing or timing chain?
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
mustangman65_79
Aug 8, 2015 12:07 PM
