service engine soon light on
Old Mar 26, 2009 | 01:35 PM
kwp289's Avatar
Car: 87 Trans Am
Engine: V8 305 TPI
It randomly comes on, happened after I hit a curb and had to get the rear end replaced. I've already put about $7500 into it and only plan on driving it for 3-4 more months. Is this serious? Anyway I could check to see what the problem is?
Old Mar 26, 2009 | 02:09 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: service engine soon light on
If you dont know how to get and read the codes, drive it to a auto parts store that will read the codes for you. Most will do it for free and give you a print out with the code and problem.
Old Mar 26, 2009 | 04:31 PM
akmusclecar's Avatar
Car: 1988 Pontiac Firebird
Engine: 5.0 TBI
Transmission: W/C T5
Axle/Gears: 3.08 Posi
There is the ADL ( automotive diagnostic link ) under the driver side dash. It is behind a small plastic cover. It will have 16 pins. 8 on top 8 on the bottom row. take a paper clip and stick both ends of the paper clip into the top 2 right pins of the connector. turn the key to the running position, the CE light will blink 1 time pause then blink 2 times . this will show code 12- ECM works. It will blink code 12, 3 times. then it will pull any other stored codes. Each code will read 3 times before moving on to the next code.
Old Apr 5, 2009 | 12:50 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
Both of my camaros service engine soon lights come on randomly, but they run fine. I think it's a way for GM to sell more needless parts. I am from old school; if it runs good, then why ***k with it?
Old Apr 6, 2009 | 04:46 AM
Icarus 402001's Avatar
Car: 92RS
To MAINTAIN running ability, mileage,etc. Sometimes, the codes are warnings.
Usually, you can head off a more severe problem by tending to a code right away.
Old Apr 6, 2009 | 04:47 PM
My camaros are running fine, and it has the check engine light come on and off at random. They get great mileage also.. when I don't have my foot in it that is..
Vintageracer
Jan 10, 2020 05:33 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
apie2546
Aug 10, 2015 05:43 PM
Omega
Aug 10, 2015 12:46 PM
