Fuel leaking at shradder valve..
Old Mar 28, 2009 | 06:56 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
After using my fuel pressure gauge I have gas bubbling out of my shradder valve. I'm assuming I need a new valve core.. Is there anything special about this valve core or would one for a tire valve stem work? They look almost the same to me, does anyone know? If not where can I get the correct one? Anyone know a part number?
Old Mar 28, 2009 | 07:51 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: Fuel leaking at shradder valve..
I would try and find one rated for use with fuel at least. The ethanol in modern gas will eat normal rubber.
Old Mar 29, 2009 | 12:33 AM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
as far as fit goes, they are the same as most tire valves.
but the seal in one for fuel is completely different.
you should be able to pick the right one up at your local GM dealer.
Old Mar 29, 2009 | 12:39 AM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
or pick up one at the junkyard. Most Schrader valves are the some from any late 80's GM car...
Infested
May 22, 2018 11:56 PM
bamaboy0323
Sep 3, 2015 06:07 AM
wayshegoes
Aug 17, 2015 12:00 PM
Kaweh
Aug 9, 2015 02:54 PM
