should I buy cylinder heads
Car: 85 camaro Z28
Engine: 305ci carbed
is it worth it to buy aluminum headsfor my 85 camaro (how much horsepower) I am taking the stock ones out tonight to clean them before i install the intake and carb i just bought and if it is what are some reasonable priced pair of assembeled heads. i found some on summit for $660 which i could save up in a few weeks. any one have some that are in fair condition i would be interestred in. thanx justin
Car: 91 rs
Engine: 383 290 cam aed carb
Transmission: th350
Axle/Gears: 4.10 ticking time bomb
Re: should I buy cylinder heads
Aftermarket cylinder heads are always a good performance gain, but how much depends on the rest of your combo, with a stock cam and exhaust manifolds the change will not be near as dramatic as with headers and a good cam. I see that you now have a 305, make sure you buy heads with 58cc chambers so that you will not lose any compression.
Transmission: 4L80E/4L80E
Keep your stock 305 heads. Put on better valve springs when you have them gone through. With cam, intake (and I hope you aren't taking off the stock q-jet - best street performance carb system out there), and exhaust, that will do all you need until you go to a 350. Even then, the heads will handle a 350 (as will the stock q-jet - it's the best street performance carb system out there).
NinjaNife
Aug 23, 2015 11:49 AM
