help! best gaskets for M/T valve covers
Old Mar 29, 2009 | 12:28 PM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
I found the same valve covers that were on the first sbc I ever bought
they were the first item to get painted with implement paint and urethane clear and have held up great on a hot and cold motor.
needless to say I have to take the alt and ac compressor off to get them in but I dont care. I really like these valve covers
anywho they leak like a sive and I cant find a gasket to seal these babies up
man I would hate to take them off.
thanks for the help and if you dont have these valve covers you will not know so please no guesses as they are a pain to do
Attached Thumbnails help! best gaskets for M/T valve covers-dscf0931.jpg
Old Mar 29, 2009 | 02:00 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Well, I don't have those valve covers, but my answer wouldn't be a guess.
But, since I don't have those valve covers, you don't want to hear what I have to say. So be it.
Old Mar 29, 2009 | 03:18 PM
mbolte's Avatar
Car: 1987 Camaro
Engine: 350 dart ies comp cam intake carb
Transmission: 700 r4, shift kit, 2400 stall
Axle/Gears: 10 bolt stock
Re: help! best gaskets for M/T valve covers
I also don't have them but I'm going to assume that that is not very important.
I had a hell of a time with chrome valve cover gaskets leaking on both my car and truck, I tried all kinds of gasket and then used a thick Mr. Gasket cork gasket and have no problems with them.
Old Mar 29, 2009 | 11:17 PM
jamon8's Avatar
Engine: 350 tpi
ok so if people have any sort of info I would greatly appreciate it
sorry I made such a fuss but I have not ran into anything like this before and was hoping that someone with mt valvecovers could tell me the appropriate gaskets to use
sorry to offend you
Old Mar 30, 2009 | 10:35 PM
five7kid's Avatar
(sniff) I just want to help . . . (sniff)
The "upgrade" gaskets will typically do a better job than the standard gaskets available from most any name brand. I haven't had much respect for what Mr. Gasket has been selling for the past several years, although their higher priced Ultra-Seal line is better than standard stuff.
I've had pretty good results with Fel-Pro. See what you think of these - http://store.summitracing.com/partde...T&autoview=sku .
FWIW, I had M/T covers like those (plain aluminum) about 30 years ago. Never had trouble with them leaking, but I had them off about once every two months to adjust the solid lifters that engine had, and used cork/rubber gaskets which lasted about 5 remove/installs before I had to replace them.
(BTW, I wasn't offended. Just intended a little light hearted humor, at your expense, of course. I'll behave now.)
Old Mar 30, 2009 | 11:21 PM
mbolte's Avatar
Car: 1987 Camaro
ya i meant the felpro cork gaskets, all the rubbers i had blew out, and blowing rubbers is always a bad thing
Old Mar 31, 2009 | 12:24 AM
five7kid's Avatar
The one I linked is a rubber coated steel shim. Not likely to blow out.
db057
Sep 4, 2015 07:57 AM
Victor6
Aug 30, 2015 02:09 AM
NBrehm
Aug 25, 2015 11:49 PM
g.l.mos
Aug 22, 2015 12:02 AM
mustangman65_79
Aug 8, 2015 01:18 AM
