How to remove plenum?
Old Mar 30, 2009 | 04:05 PM
Kolby's Avatar
Car: 1988 Trans Am GTA
Engine: 350 5.7
I bought everything I need to polish it now I just need to take it off. It was a bit more complicated then I thought but I dont have a book to refer too. Can anyone help me?
Old Mar 30, 2009 | 04:47 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: How to remove plenum?
You didn't take any pictures of it before you took it off or you still havent took in it off
Old Mar 30, 2009 | 05:00 PM
50bmgshooter's Avatar
this is just my but if you dont know how to remove a intake and being intimidated "maybe just a little" by it i wouldnt attempt to port it unless you are willing to buy a new one. again just my
but good luck anyhow
Old Mar 30, 2009 | 05:19 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Why not help the guy out instead of berating him?
8 bolts hold the plenum to the runners.
To make it easier to remove you should at least loosen up 1 set of runners.
6 bolts hold the runners to the manifold. 5 on the outside and 1 is hidden on top of the manifold under the plenum.
Remove all vacuum lines and electrical connections to the plenum.
It should lift right out. It might be stuck to the gaskets but don't worry. You'll have to replace them anyway.
Old Mar 30, 2009 | 10:19 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Or you could get someone to help you to hold the plenum while you loosen up the bolts
Old Mar 31, 2009 | 03:42 AM
89transam*pearl's Avatar
Car: 89 T/A
Engine: LB9
Transmission: W/C T-5
Axle/Gears: 10 bolt posi, 3.73 Richmond Gears
You'll need a rubber mallet to give it a few love taps after all fasteners have been removed.
Old Mar 31, 2009 | 12:45 PM
Kolby's Avatar
Engine: 350 5.7
Thanks man! Got it off and started polishing.
Thanks everyone.
Old Mar 31, 2009 | 01:36 PM
HtOwNs 87Rs's Avatar
may i ask what your using to polish this baby? thx
Old Apr 1, 2009 | 01:03 PM
Kolby's Avatar
Engine: 350 5.7
First I cleaned it as best I could. Then I sanded it down using 80 grit + sander, then 120 + sander, then 150 by hand, 200 by hand, 320 by hand, 400 by hand, 600 by hand, 800 by hand, 1000 by hand, cleaned again, eagle one polish, buff.
Old Apr 1, 2009 | 10:07 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
When it starts getting oxidized just get some very fine steel wool and go over it thats what i do to mine and it looks like you just polished it
Old Apr 2, 2009 | 04:00 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
very fine steel wool?
Mine's all polished up and i'm always looking for options on upkeep.
Where would I find such fine steel wool?
Old Apr 2, 2009 | 10:23 AM
Kolby's Avatar
Engine: 350 5.7
Would 2000 gritt sandpaper not do the same thing?
Old Apr 4, 2009 | 05:39 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
I am not sure i just do that with mine with the very fine steel wool here is a website some one else recommended this to me so i am doing it http://www3.towerhobbies.com/cgi-bin...&I=LXHZ80&P=FR
Old Apr 4, 2009 | 08:46 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
I have some of that from there. I use it on my planes. I'll try it on my driveshaft before trying it on my intake as a comparison with my other stuff.
Old Apr 4, 2009 | 10:20 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Hopefully you like it thats what i use for my valve covers and any and my tpi
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
Stroopwafel
Sep 11, 2015 06:38 AM
Nick McCardle
Sep 10, 2015 08:36 PM
