86 iroc vortec upgrade
Car: 86 iroc-z
Engine: 305 tpi
Transmission: 700r-4
Axle/Gears: 2.73 lsd
so i am in the process of swaping out the original lb9 305 heads for a new set of vortecs i got from jegs i also got the tpi intake manifold for vortec heads now i need to know what cam i should get and what rocker setup also what kind of headers will work with this? and any ideas on how to make my car faster with this motor and stock 700 r-4 tranny will help
Transmission: 4L80E/4L80E
You need self-aligning rockers for the Vortec heads.
Stock runners? Not too much cam, then. A Comp XE262 would probably be all you'd want to do.
Hooker 2055HKR headers would be perfect.
Car: 1988 Camaro IROC
Transmission: Auto overdrive
Axle/Gears: 3:23
Re: 86 iroc vortec upgrade
Rojas,
I would like to ad Vortec heads to the IROC I purchased this week. I have them on my rebuilt Caprice engine and it is a VERY strong runner!
When will you have your engine running with your new Vortec heads?
Car: 86 iroc-z
Engine: 305 tpi
should be done by may 1st ill post how it runs then im hoping to be able to run with my friends lt1 camaro he has a cold air form moroso and a magnaflow exhaust hes been bragging about how his car is way faster than mine maybe i can shut him up soon
Car: 86 iroc-z
Engine: 305 tpi
btw im hoping to get the slp runners soon i like the look and hookers do sound like a good plan how hard are they to install w/out removing motor? oh i think youre the same guy who told me to get the xe262 last time thanks i just ordered it with the timing chain and the lifter kit the other day do you think i can beat my friends lt1 with these upgrades he has the moroso cold air and magnaflow exhaust on his lt1 camaro
84z96L31vortec
Aug 20, 2017 12:16 AM
Fast355
Dec 2, 2016 06:33 PM
ambainb
Apr 25, 2016 09:21 PM
mustangman65_79
Aug 11, 2015 03:17 PM
