Ring job pricing
Old Apr 5, 2009 | 07:06 PM
Misundaztood717's Avatar
Car: 1991 Chevrolet Camaro RS
Engine: lo3 305
Ring job pricing
I've heard a typical ring job from a mechanic will run anywhere from $1,500 to 2,000. Is this normal? If so, I suppose a new engine is in order. I've got white smoke coming out of my exhaust pipes when I rev to about 3,000rpm and a puff of black whenever it's first started. I've been told a ring job's in order to cure it.
Old Apr 5, 2009 | 07:38 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Ring job pricing
Parts will probably run $500-$1000, gaskets, rings, seals etc. Everything else is labor. There's no guarentee that once the engine is torn down that it won't cost even more if other problems are found such as cracked heads, bad bearings, etc.
A new engine won't necessarily be cheaper. A long block may cost $1500+ plus will probably take the same amount of time to switch stuff over to it and install as it would to rebuild the old engine. The labor to to the swap could be more than a rebuilt.
A crate engine will cost a bit more but is more complete and will take less time to swap. The advantage of buying a new engine is that it will also come with a warranty. The more complete you can buy an engine, the easier the swap will be.
F-body driver
Mar 6, 2023 11:44 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
pimprs
Sep 10, 2015 03:34 PM
BOOT77
Sep 5, 2015 03:55 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
