valve spring question
Car: 89 RS
Engine: lo3
Transmission: 700R4 w/ B&M shift improver
Axle/Gears: 3.27 9-bolt posi
Building a vortec headed 350 with an LT4 Hot Cam. Was just wondering what a good spring would be to use with that setup. I thought maybe the GM LT4 springs would be a good fit, but maybe not. Any help is appreciated. Budget build so keep that in mind.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: valve spring question
Use the springs recommended for the camshaft and make sure they're set up to specifications.
ambainb
Apr 25, 2016 09:21 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
