roller rockers
Old Apr 5, 2009 | 10:37 PM
89_ho_rs's Avatar
Car: 1989 RS Camaro
Engine: 350 Carb(soon a 400)
Transmission: 5-Speed/th350
Axle/Gears: 10 bolt 3.73
roller rockers
I have a question about roller rockers. I want to install a set on my car. got a good deal on a set of crane roller rockers. I got home and started looking at them and they all have the number c163 except 2 of them the other two are l407 and H483. now my question is what do those numbers mean i went to crane's web site and could not find anything about those part numbers. are they a stamp of what they fit or are they a number for when they were made. they look to be the same the same stud hole and length.
also with these types of rockers can i put them on my studs and run them or do i need to put in guide plates and screw in studs?
thanks for any info.
Old Apr 6, 2009 | 03:52 PM
89_ho_rs's Avatar
Car: 1989 RS Camaro
Re: roller rockers
the only thing i know is they are for 7/16 studs. I tried them with a bolt and the 7/16 bolt is perfect. so i don't know if they are self aligning or not. if anyone knows how to tell.
Old Apr 7, 2009 | 10:00 PM
89_ho_rs's Avatar
Car: 1989 RS Camaro
Re: roller rockers
does anyone have roller rockers?
Old Apr 8, 2009 | 11:13 AM
kcallais's Avatar
Car: 1985 Z28
Axle/Gears: garbage 2.73
Re: roller rockers
If you look at the roller tip, it will have small lips on either side of the tip, those hold themselves to the spring retainer. Those are self aligning.
KO1
16
Oct 15, 2015 05:00 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
