What is the clicking noise in the rear?!
Old Apr 7, 2009 | 12:02 AM
86irocz350tpi's Avatar
Car: 1986 Camaro IROC-Z
So ive developed a clicking noise in the rear. the faster i go the faster it clicks also when i turn to the right theres a squeeling/grinding noise. what could this be?
Old Apr 7, 2009 | 12:09 AM
birdtojag's Avatar
Car: 87 Firebird, 90 bird coming soon
Engine: 355 Chevy Vortec Heads TPI, LT1 inj
Axle/Gears: 2.77 posi 9-bolt
Re: What is the clicking noise in the rear?!
Check your brakes. May be down all the way and need work.
Old Apr 7, 2009 | 12:15 AM
i dont think it would be. i mean theyre pretty much brand new. but perhaps.
Old Apr 7, 2009 | 07:54 AM
ChevyCamaro1990's Avatar
Car: Camaro RS
Engine: 3.1l v6
do u have a posi rear end? cause if so u have to have the additive mixed with the diff fluid to make it opperate properly
Old Apr 8, 2009 | 01:12 AM
84Z28406's Avatar
Car: 1984 Camaro Z28 T-tops
That's what I'd figure it to be.
Old Apr 8, 2009 | 07:51 AM
idk, i brought to the mechanic an he couldnt find it but i do have a broken sway link.
if it is the diff fluid what should i do?
Old Apr 8, 2009 | 07:54 AM
Car: Camaro RS
Engine: 3.1l v6
drain all the fluid out of the rear end and replace it manufacture specific gear oil
Old Apr 10, 2009 | 12:42 AM
i changed the fluid and put in the posi additive. and theres still a clicking but i can seem to pinpoint it. =/ perhaps it might be the brake afterall.
Old Apr 11, 2009 | 10:54 AM
birdtojag's Avatar
Check to see if there is something loose back there. Grap things and shake them. The posi additive needs a little time to get worked in. Not sure how long, but needs some time. When you check your brakes, make sure the pads are in place and not moving around.
Old Apr 11, 2009 | 12:17 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Also this may sound silly but make sure you dont have a stone lodged in the tire. Thats can make a nice clicking sound.
Old Apr 11, 2009 | 01:16 PM
third_genbowtie's Avatar
Car: 1991 camaro RS
Engine: 305-LT1 swap
Transmission: 700
the first sings of your U-joints going bad is a clicking noise. when you changed the gear oil did you by any chance see metal shavings? not to scare you but i wouldn't be surprise if your rear end is shot. that grinding noise you hear is only going to get worse
Old Apr 12, 2009 | 07:01 PM
84 maro's Avatar
Car: 84 Camaro Sports Coupe
Engine: Carb'd 5.7L 350 W/ Funct. SS Hood
Axle/Gears: Stock for now
might check your e-brake i know it sounds crazy, but mine got screwed up somehow and started making real odd noises while driving so now its unhooked. wish it wasn't need to fix that.
theshackle
Sep 17, 2020 08:26 AM
xxx3man`
Sep 23, 2015 10:37 PM
B_Dubya
Aug 26, 2015 05:09 PM
BlackBoulder
Aug 11, 2015 11:15 PM
