service engine light
Car: 1990 Camaro RS
Engine: V8 305 TBI
Transmission: W/C T5
Axle/Gears: 3.08
I have a 1990 RS 305 and I want to know if I swap the steering wheel that comes stock with an airbag, cutting the airbag wire (only possible way to remove?) will the SES light stay on?
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
Re: service engine light
no...the INFL REST (inflation restraint) will be on....make sure you do a search on how to properly remove the steering wheel so it doesn't blow up in your face....
Car: 1990 Camaro RS
Engine: V8 305 TBI
Axle/Gears: 3.08
ah alright, thanks alot 91. Might as well disconnect the INFL REST bulb if I'm d/c'ing the airbag though right?
Engine: L98 494hp
yeah you can take bulb out...but do a search on how to take wheel out....cause they can go off, even with battery unpluged
