new coil, rotor, cap and car is backfiring!
Old Apr 12, 2009 | 11:19 PM
86irocz350tpi's Avatar
Car: 1986 Camaro IROC-Z
i just put in a new MSD coil cap and rotor. And now my car backfires. would the timing be the cause? if so how should i adjust?
Old Apr 12, 2009 | 11:42 PM
1989IROC-Z5.7L's Avatar
Car: 1987 Buick WE4 Regal
Engine: 3.8L IC Turbo
Transmission: 200 4R Auto O/D
Axle/Gears: 3.42 posi
Re: new coil, rotor, cap and car is backfiring!
Are you sure that you got the wires put back on right?
Old Apr 12, 2009 | 11:50 PM
i double checked
i will check again tomorrow.
Old Apr 13, 2009 | 12:13 AM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
X2 on the correct order. Was it running fine before and now it is running like it has a miss?
Old Apr 13, 2009 | 12:33 AM
yeah it was running perfectly then started stuttering and backfiring after a few minutes.
Old Apr 13, 2009 | 12:38 AM
If the wires are right, I would put the old stuff back on and see if this fixes it. You may have a bad coil/cap/rotor. It dosent happen too often, but maybe the guy at MSD's quality control was hung-over from a wild night of Jello shots... LOL.
Old Apr 13, 2009 | 12:54 AM
hahahaha well im gonna do that and call MSD.
Old Apr 13, 2009 | 11:06 AM
RazorN8's Avatar
Car: 1987 camaro
Engine: 383 AFR heads
Axle/Gears: Ford 9" 3.70:1
I had the same problem once. I would say at least 90% chance that you messed up the firing order. Check wires for correct order again.
Old Apr 13, 2009 | 01:56 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
simple , crossed wires . good luck .
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
colton_carlson
Mar 8, 2019 12:21 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
92projectcamaro
Aug 6, 2015 01:20 PM
