Vacuum Leak
Old Apr 14, 2009 | 06:30 PM
Mrgref92's Avatar
Car: 1986 Camaro Sport Coupe
Engine: L69
Transmission: 700-R4
Axle/Gears: 2.73's
Vacuum Leak
Hey I just got my car running and I think there is a vacuum leak but I don't know where it is, there is a hissing noise and it sounds like it is coming from inside the carburetor, but it won't stay running without the gas being put on it some. Any info on where this is coming from or why it won't stay running? thanks
Old Apr 14, 2009 | 07:43 PM
50bmgshooter's Avatar
Re: Vacuum Leak
whats the idle set at? you might just need to raise the idle up a little. alot of times you here a slight hiss from the air flowing past the throttle blades at idle.
Old Apr 14, 2009 | 08:47 PM
Mrgref92's Avatar
Engine: L69
Axle/Gears: 2.73's
Re: Vacuum Leak
Tried that already, it's not like a little gas to keep it going, it's quite a lot, I kept it running for like 10-20 minutes and then it was idling fine, so idk what the problem is.
FormulasOnly
Jul 23, 2018 08:47 AM
bbsr72
Apr 2, 2016 09:12 AM
jrdturbo
Mar 31, 2016 02:58 PM
86maro_252
Oct 10, 2015 06:52 PM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
