Fuel Line Help
Old Apr 15, 2009 | 08:18 AM
bryanh1618's Avatar
Fuel Line Help
at 171k miles, i needed a new fuel pump on my 91 RS 305 TBI. I went the easy way out and cut an access panel for the fuel pump, and had to cut the fuel lines to do so. the fuel line and clamps i got from lowes looked pretty weak, does anyone have any suggestions for the permenant fix?
I am open to any ideas so that i don't have to worry about this ever again
I have seen the AN adapters they sell on Jegs, do they work pretty well, if so what sizes do i need?
Old Apr 16, 2009 | 09:19 AM
bryanh1618's Avatar
Re: Fuel Line Help
No one?? Really?!?!
Old Apr 16, 2009 | 01:00 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: Fuel Line Help
Use brass compression fittings. Especially on the high pressure line. If you must use hose, use fuel injection hose not regular cheap gas line.
Old Apr 16, 2009 | 08:10 PM
bryanh1618's Avatar
Re: Fuel Line Help
Okay, so i used the brass compression fittings, secured everything down, and go hit the key, the pump primes, and i hear a hissing noise which was gas spewing from the fittings. Didn't work very well, I'm running out of ideas here
Old Apr 16, 2009 | 08:29 PM
steve87ta's Avatar
Car: 1969 firebird, 1986 Trans Am,
Engine: 461,305TB
Transmission: T-10,700r4
Axle/Gears: 3.55,2.73
Re: Fuel Line Help
TBI should not be to high as fuel pressures go. (vortech are up to 60 psi !) A pic may help. Also plumbing for water is done with compression fittings-so it should work. I can tell you that AN adapters to hard line are available in some sizes but they do work like the compression fittings though. Maybe you are not getting the comp ring in the right spot-they should go where the angled edge so that as they get tighter they "compress" on the outside of the tube. I use them on 80 psi paint lines at work and they do work. HTH
AN fittings also use an inverted flare union and all the adapters and ect can ad up$ fast.
ljnowell's Avatar
Re: Fuel Line Help
Not to sound like a total ******* here, but this is exactly why those of us who have lots of car knowledge always belittle poeple doing this exact same thing. Then dozens of hacks come in and enourage it, now you get to deal with the problems. You forever have butchered fuel lines on the car. YOur best bet at this point would be to get some decent quality hose clamps and use some good quality fuel line and double clamp it. Dont look for a lot of help.
Old Apr 16, 2009 | 08:35 PM
bryanh1618's Avatar
Re: Fuel Line Help
Thanks for nothing!
Please don't reply if you do not have useful information
Old Apr 16, 2009 | 09:13 PM
jv9999's Avatar
Engine: 5.7L/350
Re: Fuel Line Help
Tighten them down more. I'm assuming the line was clean and you used the right size fittings. They will work if used right.
Old Apr 16, 2009 | 09:14 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Re: Fuel Line Help
If this is what you want to do, go for it. i did and have no regrets.
There's a picture of my so called "hack job" on my second reply to this post https://www.thirdgen.org/forums/tech...-question.html
I used fuel injection hose on all, but the supply line. The 3/8" coupling you see is a carbon steel Swagelok tube to tube fitting. You can find a distributor here http://www.swagelok.com/distributors...nited%20States
Old Apr 17, 2009 | 01:55 PM
bryanh1618's Avatar
Re: Fuel Line Help
Thanks guys, for the info,
jv, I tried tightening them down more, but i think i stripped out the brass fittings so this complicates things a little. I'm going to try rgarcia's way and go with carbon steel fittings. The website you sent me for swagelock gives the closest dealer to me about an hour away, going to try to go there this weekend and pick up all the fittings.
I'll keep you posted on my progress.
PS rgarcia, your "hack job" looks pretty clean, good job, did you polish your gastank while you were in there? its shiny
Old Apr 21, 2009 | 07:49 AM
bryanh1618's Avatar
Re: Fuel Line Help
Got an update,
Went to parts store and picked up 2ft of fuel injection rated fuel line, double clamped everything with fuel hose clamps (not pressure clamps from hardware store) and everything is secure, no leaks, car runs great.
Old Apr 22, 2009 | 03:00 PM
ljnowell's Avatar
Re: Fuel Line Help
Thanks for nothing!
Got an update,
I guess my useless information was good for something huh?
BTW, those are called hose clamps and rubber line. Labeling it as fuel injection is to make people feel good about using it. It doesnt matter what psi the hose is rated for, its the hose clamps at the end that dictate its potential.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
