long or short water pump?
Old Apr 15, 2009 | 03:48 PM
5literTPIterror's Avatar
Car: 91 camaro rs
Engine: 355, blowthru, 78mm turbo
Transmission: th350, art carr converter
Axle/Gears: stock 7.5, 3.23s, minispool
im using a passenger side top mounted altenator and stock location powersteering pump, which JEGS aluminum mechanical water pump do i buy? long or short?
(small block chevy)
Old Apr 15, 2009 | 07:07 PM
50bmgshooter's Avatar
Re: long or short water pump?
serp or v belt? serp usually runs a reverse rotation water pump!!!
on the water pump if you can fit your fingers behind the water pump and in front of the timing chain cover its a long pump if not its a short pump
Old Apr 15, 2009 | 08:26 PM
89importeater's Avatar
Car: 89 RS camaro
Engine: 454 swap in progress
Transmission: th400
Axle/Gears: 4.11
i thought only motors like the LT1 used the reverse water pump, hum learn something new everyday
Old Apr 15, 2009 | 11:28 PM
gurkgurkgurk's Avatar
Car: 86 Camaro iroc-z28
Axle/Gears: 3.42 Posi
long style waterpump.
and importeater, although a serpentine drive turns the waterpump the opposite way, the flow of the coolant is still the same. LT based engines have a reverse flow of coolant. so the heads get the coolant first as opposed to having the coolant go in the bottom, like in ours
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Jan 9, 2020 08:29 PM
Street Lethal
Apr 30, 2019 12:14 PM
MoJoe
Sep 24, 2015 09:12 PM
Dialed_In
Aug 20, 2015 01:45 PM
