I'm Stupid
Old Apr 15, 2009 | 09:49 PM
Duts87ss's Avatar
Car: 1987 Monte Carlo SS
Engine: HSR 383 AFR180/268XFI EBL
Transmission: 200-4R, Edge 2800 L/U
Axle/Gears: 7.5/3.73/PowerTrax No-Slip
I'm Stupid
Guys, I made a boo boo. When I had the small coolant leak with the HSR and rinsed it with the hose, I didn't have the valve covers bolted down ( only sitting on the studs and gasket). I had some "milkshake" on the dipstick and some coolant in the pockets on the heads. I didn't even think about not having the covers tight until today; when I was going to try to start it for the first time since installing the intake.
Do you think I will be okay to drain the oil, install new oil and filter then run engine to operating temp, drain, change filter and be good to go?
Old Apr 15, 2009 | 09:57 PM
Stephen's Avatar
Car: 87 GTA
Re: I'm Stupid
That's what I would do. Plus pull both valve covers & get out any standing water puddles.
Old Apr 15, 2009 | 10:09 PM
Duts87ss's Avatar
Re: I'm Stupid
Thanks for the extra confidence. Will do on drying up the extra water in the heads; driver side is already done.
Old Apr 15, 2009 | 10:50 PM
Stephen's Avatar
Car: 87 GTA
Re: I'm Stupid
I started thinking......
If you can, Do you have a shaft to spin the oil pump, without starting the car? You'd hafta pull the dizzy, insert the shaft, then spin the oil pump to pump oil & leftover water through the system, hoping to flush as much as possible, down to the oil pan.
Might be overkill protection, but better than cooking bearings.
Old Apr 16, 2009 | 12:18 PM
Duts87ss's Avatar
Re: I'm Stupid
I do, and I thought about that myself. I may go that route; just have to find my oil pump primer.
djmarch
Oct 2, 2015 10:41 PM
83ho87gn
Sep 26, 2015 08:49 PM
spartanreaper
Sep 25, 2015 07:22 PM
83ho87gn
Sep 24, 2015 08:58 AM
gta892000
Sep 16, 2015 12:37 AM
