Valve cover question
Old Apr 19, 2009 | 01:04 PM
gcgarner's Avatar
Car: '92 T/A WS6 Vert/1956 Chevy Nomad
Transmission: 700r4 w/ Transgo Kit
Axle/Gears: 3.42 LSD
OK, dumb question probably, but I just don't want to throw oil all over the place.
I have polished valve covers on the new 350 (around 1000 miles old). I began to remove my driver's side valve cover in order to give it a good polishing, but after I removed the bolts and tried to wiggle the valve cover out, I found out it was going to be more trouble than it was worth just to clean. Plus I saw that just unplugging the alternator wire would give me access to the area I wanted to clean. So, I decided just to put the valve cover back on. It never got more than a 1/2 inch or so away from the head. I laid it back on the head and tightened the bolts down.
So, my question is: Is there any way I could have messed up/misaligned/pinched the valve cover gasket during this process? It is a new rubber gasket. I know it doesn't currently leak. But before I started the car and threw oil everywhere, I just wanted to make sure I was good to go.
Thanks!
Old Apr 19, 2009 | 01:18 PM
J91's Avatar
J91
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Re: Valve cover question
It's probably fine, I didn't so I don't know, only you do, just put it on and have someone else start the car, and watch for a leak, if it leaks tell them to shut it off, and fix it. Good luck
Old Apr 19, 2009 | 03:43 PM
gcgarner's Avatar
Thanks. It's fine. I was just a little paranoid.
MoJoe
Sep 24, 2015 09:12 PM
NBrehm
Aug 25, 2015 11:49 PM
db057
Aug 22, 2015 08:17 PM
1985chevydude
Aug 20, 2015 12:29 AM
mustangman65_79
Aug 8, 2015 01:18 AM
