3.1 v6 engine error codes
Old Apr 24, 2009 | 10:08 AM
Timmie's Avatar
Car: camaro
Engine: 3.1 :(
Axle/Gears: stock
my engine ( 3.1 V6 ) is doing funcie these last weeks.
first 2 mornings it wouldnt start. the starter would work but it would do anything.
then this morning my car started but within 5 secs it stopped.
2 times. after a third attempt it started running and stayed running.
i read my errorcodes.
code 13 oxygen sensor circuit
code 23 manifold air temperature sensor
code 33 map sensor
code 42 electronic spark timing
code 45 rich exhaust
anyone knows what this could be ?
Old Apr 24, 2009 | 06:36 PM
dr.fiero's Avatar
Car: '91 S10 Blazer
Engine: TBI 350
Axle/Gears: 3.73 posi
Re: 3.1 v6 engine error codes
You went from fine one day to ALL that?! Wow.... that really sucks!!
Almost sounds like you lost a portion of your wiring harness though. A lot of those all use a common ground. I'd look around and see if you dropped a ground cable (or a few!) somewhere as a starting point.
Remember there is Bat -> Blk, Blk->Frame, Blk-> Chassis, etc etc....
Old Apr 25, 2009 | 01:37 AM
Timmie's Avatar
Car: camaro
Engine: 3.1 :(
Axle/Gears: stock
can you tell me where the common ground is located ?
else I just wire them straight to the battery.
Old Apr 25, 2009 | 09:57 AM
dr.fiero's Avatar
Car: '91 S10 Blazer
Engine: TBI 350
The sensors (less the O2) all common back to the ECM.
There will be usually a braid going from the block to the firewall.
Even if they're THERE... they should still be pulled, polished clean, use something like anti-sieze or no-lox on the now clean surfaces and bolt them back tight.
cking99
Sep 22, 2015 11:33 AM
rscamaro91
Mar 16, 2001 11:22 PM
jody92RS
Mar 7, 2001 09:59 PM
auxout
Jan 21, 2001 03:22 PM
FBODY-ADDICT
Dec 14, 2000 01:02 PM
