So where exactly does this connect to?
Old Apr 25, 2009 | 06:45 AM
AndrewSyndrm's Avatar
Car: 1988 Firebird Formula
Engine: 305 TBI..not for long
Transmission: Automatic
Axle/Gears: stock
okay... i think this is related to my vacuum leak, but does this hose connect into the side of the air filter pan? it has no where else to go, but it doesn't seem to fit into the cut-out in the pan easily..
and one more...... (the rubber black hose under the pan base)
i found this under the pan base, but i think its just a vent hose... but im not sure. anyone know where it goes?
i can't seem to find any diagrams anywhere with my answer, i appreciate the help.
Last edited by AndrewSyndrm; Apr 25, 2009 at 04:07 PM. Reason: sorry for the bad links.. hopefully these work.
Old Apr 25, 2009 | 10:05 AM
Axle/Gears: stock
Re: So where exactly does this connect to?
anyone?
Old Apr 25, 2009 | 10:21 AM
burn0ut305's Avatar
Car: z28
Transmission: pro built 700r4 (road racing kit)
pics arnt working...
Old Apr 25, 2009 | 10:42 AM
Knuckles_up's Avatar
Car: 1985 Camaro
Engine: V6
Yea if I can get a pic of what is wrong I will prolly be able to figure out what is wrong with it. I had a vacuum issue just yesterday and I pretty much memorized the entire system.
Old Apr 25, 2009 | 04:48 PM
Axle/Gears: stock
okay, i just re-posted the pictures... are they working for ya'll?
Old Apr 25, 2009 | 04:54 PM
Car: 1985 Camaro
Engine: V6
try connecting it to the hose... I am not sure because I don't have a carb....
Old Apr 25, 2009 | 04:56 PM
JTNKTZ's Avatar
Car: 1991 Camaro RS/1989 Vert RS
Engine: 355/350
Transmission: T-5/T-5
Axle/Gears: BW9bolt3.45posi/3.23 Posi
It connects to the side of the filter. If you look at the side opposite of the filter cone there should be a hole that size. Just look around the metal filter and you will find it. It is near the passenger side of the filter. As for the smaller one, I'll go look now for you.
Old Apr 25, 2009 | 05:01 PM
JTNKTZ's Avatar
Engine: 355/350
The smaller one connects to the front of the carb. It is more towards the driverside in the front.
Old Apr 25, 2009 | 06:31 PM
Axle/Gears: stock
thank you very much this helped out my problem from what i've seen so far, but my starter just cracked... but im about to go install a new one now. thanks again
InfernalVortex
Apr 20, 2021 11:31 AM
bplessy
Sep 30, 2015 12:14 PM
Gordonr1973
Sep 29, 2015 11:59 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
