No Spark!!!!
Old Apr 27, 2009 | 09:40 AM
POP6482's Avatar
Car: 1989 Iroc-Z Convertible
Engine: 6.0 LQ4 LSX
Axle/Gears: Moser 12 bolt w/4.11s
No Spark!!!!
Car just died at a stop sign Friday night. Cranks and Cranks but wont turn over. I know its getting fuel the pump turns on and Im getting fuel in rail.
Checked for spark yesterday and there is none at the Distributor. How do i diagnose this problem and track down the cause
I did replace the cap and rotor last year and have only put about 10 miles on the car since then they are still like brand new
possible ideas right now
coil
ignition module
bad ground
blown fuse
ECM
not sure let me know
thanks for any help
Old Apr 27, 2009 | 09:48 AM
3rdgengmachine's Avatar
Car: 87 iroc z
Engine: 358 tpi
Transmission: 700r4 with transpack
Axle/Gears: 3.42 with powertrax
Re: No Spark!!!!
id check for spark at a plug first. pull a plug wire off the plug and check it there if no spark at all id bet its the magnetic pickup trigger in the distributor if you have another one laying around slam it in and try it if it runs or sparks it will be the pickup.there easy to change just knock out the pin in the gear and slide out the shaft and bolt it in hope it cures it
Old Apr 27, 2009 | 12:14 PM
Fyrstorm's Avatar
Car: 86 Trans Am
Engine: 385 Fast Burn
Transmission: 700R4 - stock (eep!)
Axle/Gears: Stock, will upgrade at some point
Re: No Spark!!!!
Seems to be common these days!! I have the same problem right now and have narrowed it down (hopefully) to that. Posted in another thread too, same topic hehe!
Old Apr 27, 2009 | 12:48 PM
Car: 87 iroc z
Engine: 358 tpi
Re: No Spark!!!!
did it backfire or start missing alot after it got warm thats another shure sign of the pickup then when it gets cold it will run fine but sometims they just go stright out and wont fire at all
Old Apr 27, 2009 | 01:10 PM
kcallais's Avatar
Car: 1985 Z28
Axle/Gears: garbage 2.73
Re: No Spark!!!!
These are also symptoms of a failing Ignition Module.
Old Apr 27, 2009 | 07:38 PM
POP6482's Avatar
Engine: 6.0 LQ4 LSX
Re: No Spark!!!!
it ran fine the whole night no sputtering or missing at all......just died and wouldnt start had to trailer it home..cars in my fathers garage at his house hoping to get over there tomorrow to figure it out
thanks
Old May 1, 2009 | 12:55 PM
POP6482's Avatar
Engine: 6.0 LQ4 LSX
Re: No Spark!!!!
changed the ignition module yesterday and it started right up. Thanks for all the help
Old May 1, 2009 | 08:49 PM
Fyrstorm's Avatar
Car: 86 Trans Am
Re: No Spark!!!!
Good to hear!
RedLeader289
May 28, 2019 01:47 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
