white smoke did i cause any damage to my engine
Old Apr 27, 2009 | 02:32 PM
godreject's Avatar
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
upon doing an hsr swap and trying to fix all my mechanical glitches,
my 88 iroc puffs put white smoke with a strong fuel smell. seems to be running very rich, Car sat for quite a while i noticed the oil has signs of water so i replaced the oil. added new gas replaced fuel filter and added fuel injector cleaner, oil and fuel stabilizer. I drove the car 25 miles or so back home from the shop with white smoke pouring out the exhaust the whole time. Car has good power idles a bit high(hsr issue) but will not stop smoking. Im leaning towards a water leak from a faulty intake gasket since i recently replace that, ? is driving the car 25 miles could i have caused any further damage, i doubt i have a head gasket issue but even if i did would replacing my heads, intake gasket cure my problem. Any help is apreciated thanks
Old Apr 27, 2009 | 05:00 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: white smoke did i cause any damage to my engine
Remove the intake, get new FelPro gaskets and Edelbrock gasgacinch, and get the intake sealed to the heads. Then replace the oil and filter. Running righ makes black smoke, coolant makes white smole, oil makes blue smoke, and if you have a TH350 with a bad vacuum modulator, that makes white smoke, but not huge billowing clouds.
Old Apr 27, 2009 | 07:08 PM
godreject's Avatar
im running 1205 gaskets, i will check my water level and see that, my ? is did i cause any damage by running the car in this manner, engine wise, the car was puffing out white smoke with a serious gas smell by the way what is that eldelbrock product
Old Apr 28, 2009 | 11:21 PM
Nub383's Avatar
Car: 94 Silverado
Engine: 383 Vortec TBI
Transmission: 4L60
Gasgacinch is a sealant
Vintageracer
Jan 10, 2020 05:33 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
