aluminum heads
Old Apr 29, 2009 | 11:18 PM
BLUEBABY's Avatar
Car: 89 iroc
Engine: 305 tbi
Axle/Gears: 273 10 bolt
aluminum heads
Fellas, i have an 89 iroc with a 305 tbi. I was able to get a 89 formula 350 as a donor car and am preparing to do a swap. my question is i have access to aluminum heads off an 89 vette for very cheap. These heads should work fine and be a better option than cast iron ones right?
Old Apr 29, 2009 | 11:52 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
Re: aluminum heads
first the vette heads do not have a bypass for the egr valve - if you are using a tpi or tbi intake system.
im not sure but they might be bigger than the 58cc you need. but there is also a chance you could get the 54cc ones. if they are the 64 cc ones they are too big and you will lose compression.
someone else jump in here about the cc of the heads, becaue im not sure.
and for your information anything is better than swirl port heads as i have been told a number of times.
now look to the red line at the top of the screen. there is a word there, and the word is SEARCH. use it - it works well. if you are lucky you will only find 10 pages of links to this topic.
good luck and welcome to 3rd gen.
Old Apr 30, 2009 | 07:06 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: aluminum heads
I think my friend tony is confused. As I understand you, you have an '89 Formula, that currently has a complete, iron-headed 350, in it, and you want to put the vette heads on that 350, and put that 350 in your IROC. No difficulty there. The aluminum 'vette heads were only made with 58cc chambers, which is fine. The '89 350 has about 9.1:1, NOT the 9.3:1 GM claimed, with iron 64cc heads. Going to the 'vette heads will give you about 9.7:1. If you need your EGR working correctly, you'll need the complete EGR system from the 'vette, as the aluminum heads don't have the necessary pssages. This is fine, because the 'vette heads also need you to either change the lower intake manifold, or modify the one you have. If you do pull the heads off the 350, verify how far in the hole the pistons are, at TDC. If they're down more than .020", use FelPro steelshim head gaskets.
Old Apr 30, 2009 | 05:08 PM
BLUEBABY's Avatar
Car: 89 iroc
Engine: 305 tbi
Re: aluminum heads
I do not have the complete egr setup off the vette, just the aluminum heads. Since the car doesnt need emmissions, Is there a blockoff plate to eliminate the egr?
Old Apr 30, 2009 | 05:58 PM
IROCtheThird's Avatar
Car: '89 IROC-Z
Engine: LSx
Re: aluminum heads
Yes there is. A few places make them, but go to custombilletworks.com, they make one for a decent price. But you also need to have the EGR system removed from your ECM otherwise you will get a code and the car wont run right.
Old May 1, 2009 | 12:17 AM
BLUEBABY's Avatar
Car: 89 iroc
Engine: 305 tbi
Re: aluminum heads
so it seems to me by reviewing all the topics on this swap, I have everything needed off the 89 firebird donor car to make this swap work. I have the complete motor and harness and ecm. The only thing i need is the fuel pump for a tpi 350 and a computer reflash if i am going to block off the egr. Is anything missing?
Old May 1, 2009 | 12:42 AM
Car: 1990
Axle/Gears: stock
Re: aluminum heads
HOW DARE YOU SAY I AM CONFUSED. I AM NEVER CONFUSED - but i have been known to be wrong on one occasion, ok maybe more than one, ok at least once a day i am wrong, as i am in this case. darn that means two times that day.
i did not read it correctly about the swap. sorry.
Old May 1, 2009 | 08:25 AM
BLUEBABY's Avatar
Car: 89 iroc
Engine: 305 tbi
Re: aluminum heads
Its ok to be confused. I always am!
Old May 1, 2009 | 10:23 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: aluminum heads
Don't mind tony, he just has a great sense of humor.
Old May 1, 2009 | 10:39 AM
BLUEBABY's Avatar
Car: 89 iroc
Engine: 305 tbi
Re: aluminum heads
I just started on third gen and i think you guys are great!
Old May 1, 2009 | 01:37 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: aluminum heads
Thanks, and welcome!
Old May 3, 2009 | 09:57 PM
BLUEBABY's Avatar
Car: 89 iroc
Engine: 305 tbi
Re: aluminum heads
In keeping my 350 to a low budget stock rebuild, is there a mild cam that you guys reccomend and possibly 1/6 rockers
Old May 4, 2009 | 11:41 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: aluminum heads
for a mild TPI I believe I'd like a Comp XE252HR10. If you want 1.6:1, be sure to have the heads machined for pushrod and retainer-to-guide clearance before assembly.
midge54
Dec 27, 2019 04:14 PM
italiano67
Aug 31, 2015 06:04 PM
bdads
Aug 24, 2015 06:01 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
