Knocking/Tapping in reverse only
Old May 1, 2009 | 07:13 PM
sschevy400's Avatar
Car: 91 z28
Transmission: auto :(
So what now huh....When the car is in reverse it will knock/tap. Cant locate it at all. Must be the trans?
What do you guys think?
As soon and you put it in park or drive, the noise stops. Place it back in reverse and it comes back. It will tap faster with engine RPM also. some days it there...some its not.
Any ideas? thanks guys
Old May 1, 2009 | 07:15 PM
dr.fiero's Avatar
Car: '91 S10 Blazer
Engine: TBI 350
Axle/Gears: 3.73 posi
Re: Knocking/Tapping in reverse only
I'm thinking motor or trans mount. Torques in the opposite direction in D vs R of course.
Pop the hood, do a partial (not all the way!) brake stand in drive, then do it again in reverse. See how much the engine tilts over each way (should be about equal).
edit: oh yeah... heh... if it does move too far over, I'd start with checking the fan shroud for signs of hits.
Old May 1, 2009 | 07:27 PM
sschevy400's Avatar
Car: 91 z28
Yea i thought of that...but electric fans.
I just tried it and the motor moves about 1 1/2 inches in drive and reverse when giving it quick stabs of the throttle with the brake held.
Old May 1, 2009 | 07:28 PM
BtownZ28's Avatar
Car: 1984 Z28
Engine: 305 LG4
I vote trans mount- replace it and see what happens.
Old May 1, 2009 | 07:38 PM
dr.fiero's Avatar
Car: '91 S10 Blazer
Engine: TBI 350
E-fans, ah yes! Oops.
So, when you did the mini brake stand, did you get any noises?
If not, you've narrowed it down to half the trans, or the driveshaft (etc).
I'd lift up the back end, then run it backwards. See if the noise is still there.
jagevileye21's Avatar
Car: 1991 Z28 Vert
Engine: LT1 350
Transmission: T56 6 Speed
Axle/Gears: 3.42 LSD
My car does the same thing when I put it in reverse (a loud bang) and I have new polyurthene trans mount. Now I'm leaning more towards torque converter being slightly loose, u-joints or bad yoke.
Jay
Old May 1, 2009 | 07:49 PM
sschevy400's Avatar
Car: 91 z28
No no noise this time. But it does come and go. It doesnt bang hard, its just taps. I can put my hand on the trans and feel it....almost like the flexplate is rubbing. But then next time, it wont do it at all.
I'll try a trans mount and see what that does
should i get a poly? or a stock one?
Old May 1, 2009 | 07:58 PM
dr.fiero's Avatar
Car: '91 S10 Blazer
Engine: TBI 350
Your call, but... they're so cheap... I'd toss in a poly from Energy Suspension or whoever floats your boat.
But the way you're saying comes and goes - I'm starting to lean away from it being a mount.
Old May 1, 2009 | 09:15 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
I vote for a cracked flex plate.
Old May 2, 2009 | 04:16 PM
el_muerte's Avatar
Car: '87 Z-28
Engine: LT1-topped 400
make sure it's not the exhaust hitting the transmission, i had a similar problem... strange knocking sound that comes and goes, changes with engine speed, and comes from transmission area.
Old May 16, 2017 | 11:29 PM
gavin.priestley's Avatar
Car: 1988 Pontiac Firebird
Engine: 305 V8, TBI
Hey guys im new here, and I know this is kind of an old thread, but I'm having a problem with my bird, like when the car is cold, the engine is fine, but as soon as the engine reaches normal temperature and I put it in reverse or drive I hear a kind of knocking/lifter sound. But then if i put it back in Park, the noise goes away. I just changed the oil, replaced the oil pump with a HV one and put a new oil filter too. When me and my dad were down there he noticed a bad bearing on the crank, so we replaced that as well, it was the only bad one, so idk now, idk is it the lifters?
Old May 17, 2017 | 01:22 AM
GeneralDisorder's Avatar
Crank bearings feed rod bearings - did you check those too?
It's not usually a great idea to roll bearings into an engine once one has "gone bad". Do you have any pictures of the bad one?
GD
Old May 17, 2017 | 08:32 AM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
Don't rule out an exhaust manifold leak.
Since the exhaust is somewhat restrained by its mounts to the chassis, a "barely-there" exhaust leak could be opened up when the engine+transmission torques over one way in reverse, and closed up when in neutral or torqued over in a forward gear.
F-body driver
Mar 6, 2023 11:44 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
Veaceonee
Sep 29, 2016 08:15 PM
nova983
European Region
Nov 2, 2015 12:15 PM
84redta
Sep 19, 2015 09:58 AM
