Rear Main Oil Seal Replacement ?
Car: 1987 IROC z
Transmission: 700R
Axle/Gears: POSI 3:27s
Car is a 1987 with the 350 TPI. I have access to a hoist and a Buddy with a transmission stand to help remove the transmission.
Both of us very mechanically inclined. Looking for any tips to make the job go smooth and no headaches ?
I want to replace all seals and fluids involved in the job. So next question is does Anyone Have the part numbers for the Rear main seal and oil
Pan gaskets etc for OEM replacements if they are available or I would think these should be available at Napa? Is there a transmission filter in these?
I work away so just like to order the all parts that are or may be needed while I am away and be able to get it done quick and not loose any driving time.
Re: Rear Main Oil Seal Replacement ?
You don't want OEM on the pan gasket at least. Fel Pro and others make one peice reusable gaskets out of silicone.
There are much better options than OEM in this particular category. Others will have more suggestions I'm sure.
GD
GD
Car: 1987 IROC z
Transmission: 700R
Thanks for that advice. With that type of gasket do I have to use some silicone sealant as well as the gasket or not needed?
No they are generally installed dry. They incorporate crush sleeves and come with longer bolts where necessary as well as some neat little plastic threaded studs that hold the pan in place so you can install the bolts, etc.
GD
GD
Transmission: 4L80E/4L80E
You don't have to drop the pan to replace the rear main seal.
These aren't known to be leakers like the old 2-piece rear mains were. Are you sure that's where the leak is coming from? The distributor, intake, and oil pressure sender are more likely. As is the oil pan, for that matter.
Car: 1987 IROC z
Transmission: 700R
I'll be checking everything over hopefully this weekend on the hoist but from being under the car in the garage it really looks like it's coming from the seal.
I replaced the oil pressure sensor last ward
You might want to do yourself a favour and give the engine a thorough cleaning. If you can spray the engine (Gunk Engine Brite at Canadian Tire works well) while it's on the hoist, so much the better. Then let it run for an hour or so. You may save a lot of time and effort.
Car: 1987 IROC z
Transmission: 700R
Yup I'll do that for sure. I have 2 cans sitting on the shelf in the garage.
Thanks for the tip!
Thanks for the tip!
articwhiteZ
Nov 11, 2017 01:35 AM
