86 camaro tpi problems starting
Old May 3, 2009 | 02:07 AM
meister28's Avatar
i have an 86 camaro the last couple of weeks its been tuff to start in the mornings will keep turning over then eventually start but will bog out, have to restart and rev a few times but if i let off it just dies. after a few times it eventually idles fine and lasts all day starting and stopping. but the longer I let it sit over night the longer it would take to start. now i left it for two days and wont start at all. any advice?
Old May 3, 2009 | 09:25 AM
Vader's Avatar
Re: 86 camaro tpi problems starting
What is the standing/running fuel pressure?
Old May 3, 2009 | 12:19 PM
meister28's Avatar
when crankin it says 60
Old May 3, 2009 | 12:41 PM
3rdgengmachine's Avatar
Car: 87 iroc z
Engine: 358 tpi
Transmission: 700r4 with transpack
Axle/Gears: 3.42 with powertrax
umm can you look at a few plugs after it has sit for a while and b4 you try to crank it or even hit the key switch at all to see if there soaked in fuel but i kinda doubt thats it but better check it anyway to rule it out.The bogging sounds like your not getting enough fuel.Anytime an engin boggs it isnt getting enough fuel so its sounding like a cold star injector or cs switch problem.Look at the plugs first and well go from there
Old May 3, 2009 | 12:43 PM
meister28's Avatar
thanks ill give that a try
Old May 3, 2009 | 12:46 PM
Car: 87 iroc z
Engine: 358 tpi
ahh after reading your post agin its sounding like a fuel pump problem or relay try this first have someone help you get them to try to start it while you spray some gas or starting fluid in the throttle body i use a windex bottle with gas myself it should fire right up.but try that first and see what happens
Old May 3, 2009 | 12:56 PM
meister28's Avatar
alright so try starting it before checking the plugs?
Old May 3, 2009 | 01:14 PM
Car: 87 iroc z
Engine: 358 tpi
lol sorry about the confusion i should have edit that message insted of just reposting but yea go ahead and check the plugs first real quick just to see if the injectors are bleeding pressure and flooding it on start up it happend to me on my 87 and i just went ahead and replaced them but anyway yea check the plugs then try to start it without spraying fuel into it and if it dosent start spray some gas or starting fluid into the throttle body and it should fire right up.If it does and keepd running fine its probly a cold start injector issue.If it just fires and dies and you can only keep it running by keeping on spraying fuel into it youve got a pump going out.Let me know what happens..
Old May 3, 2009 | 03:39 PM
Vader's Avatar
FWIW, 60 is way too high for a stock setup. I don't even run over 50 on a TPI 355 running 19# injectors. The POS old style RP and Bosch injectors tend to go static at 60. It might be flooding.
Old May 3, 2009 | 08:00 PM
meister28's Avatar
it has bigger injectors than stock not sure what size they came on the car when I bought it an has a bbk intake tha big box. I figured out the problem though, it was the computer thing in the distributer I replaced it like a month ago, but I tried the old one again and it fired up no problem no bog! wooohooo! thanks for the input though.
Old Nov 7, 2011 | 01:29 PM
gera_lopez21's Avatar
I have the same problem with my car, I know it's a little late to ask but did you solved the problem?, in my case in the morning I have to leave the switch on for at least 1 hour, after that the car turns on with no problem , but I'm still having the same problem the next day
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
