Jump start, then turn off won't start again??
Old May 3, 2009 | 08:09 PM
CamaroRS1989's Avatar
Car: 1989 Camaro RS. Nissan Altima
Engine: 2001 5.7L LS1
Transmission: 4L60E w/ Circle D 3500-3600 Stall
Axle/Gears: Stock 3.42
I've had my 89 camaro for 13 yrs and it's been garaged for the last 4 yrs. I go out and start it a few times a year and drive it a short distance. I have to hook it up to a charger on the start setting (300amps?) to get it to start. Then once it's started it'll stay running and drives, but when I shut it off it's dead and won't start... nothing when I turn the key. What could be the problem? The battery is 3-4 yrs old but I think when it was new it still had the same problem. I hope it's something simple, I just don't have much time to mess around with it and guess things
Thanks for any help!
Old May 3, 2009 | 11:09 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: Jump start, then turn off won't start again??
It's your battery. You jump start the car, the alternator keeps everything running. With the battery not holding a charge, as soon as the alternator's charge goes away, there is nothing to start the car. Pull the battery, take it to autozone/sears/checker/advanced auto and have them test it.
Old May 4, 2009 | 06:43 AM
50bmgshooter's Avatar
could also be the alt if its shorted internally. just changed one like this on a friends car
Old May 4, 2009 | 07:23 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Maybe, but if it is shorted internally, he'd get erratic readings on his gauge (it would be jumping up and down) or it would read low, like around 10-11 instead of 13-14.
Old May 4, 2009 | 07:29 AM
Codename 47's Avatar
Car: 1986 Camaro Z28
Engine: 400
Axle/Gears: 10 bolt Posi 3.73
My guess is it's the battery.
Wade787b
Sep 29, 2015 01:15 PM
backtothe80s
Sep 5, 2015 12:39 AM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
