Engine flooded? or bad distributor?
Old May 5, 2009 | 03:45 PM
SpaniardV6's Avatar
hello,
I start the engine, sounds perfect, and after 2 minutes, the fan start, no SES engline light ON (light is OK, because when turn the key to position 1, light goes ON, start the engine and light goes OFF).
Start the fan, and start the problem... push throttle slowy and the rev goes to 2.000 rpm without problem, but If push full throttle the rpm goes down if there is no fuel or excessive fuel?
I replaced coil, injectors, sparks, spark plugs, wire from coil to distributor, HEI module, Throttle Position Sensor, Cold Water Temp Sensor, O2 sensor, MAP, MAF, IAC (idle valve control?).
New fuel filter, air filter, new fuel pump, new fuel pump relay...
The only part I don't replace, is the rotor cap and rotor (distributor) because I don't change it.
Any ideas?
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
Wade787b
Sep 29, 2015 01:15 PM
86IROC112
Aug 17, 2015 02:00 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
