Flat spots in throttle
Old May 6, 2009 | 10:04 AM
8urv8's Avatar
Car: 1992 Camaro RS
Engine: 3.1L V6 w/.425" cam (Int. & Exh.)
Axle/Gears: Stock
Hey guys. I was wandering, my throttle has alot of "flat spots" below about 75%. do you think I should replace the TPS? I can gently push the gas when I take off and it will start going, then it will flatten off until I give it a little more gas, It's just in certain spots below about 3/4 throttle. I have seen something in the Summit catalog that plugs in-line with the sensor that's supposed to get rid of dead spots, but should I try to replace the sensor first?
Old May 6, 2009 | 10:24 AM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
Re: Flat spots in throttle
does it appear to bog down or just lose power like its starved, or does it appear to lose spark?
Old May 6, 2009 | 10:34 AM
8urv8's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
No, none of the above. It's like im letting off the throttle. the power seems to level out until i give it a little more gas, then it sets me back in my seat.
Old May 6, 2009 | 10:50 AM
ls six's Avatar
There should be instructions on the forum showing you how to test the TPS.
I believe it is bad in this case but allways test instead of throwing parts at a car.
if the voltage dips and spikes when you open the throttle ( slowly and smoothly ofcourse then it's bad.
You'll need to set the new TPS anyway (if it's an adjustable style with slots) and this method will come in useful.
If you dont have a Volt/multi meter you can buy a cheap one for $5 or so at some auto parts stores.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
DiabloWS6
20
Dec 11, 2015 04:12 PM
Randomtask2
Sep 7, 2015 05:06 PM
TheExaminer
Sep 6, 2015 11:40 PM
