Help! Engine misfire under load.
Old May 6, 2009 | 10:26 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
I'm having an issue of the engine breaking up under a load. Starts and runs fine but if you give it throttle it'll break up like crazy. It's a sbc with a new pro-systems carb, afr heads solid roller cam, 10.4 compression. Plugs didn't change anything and a new cap and rotor didn't help either. It does have an MSD 6al ignition with an HEI though. Any ideas? Probably change the coil next. Help!
Old May 6, 2009 | 10:54 PM
LuckyGen3's Avatar
Engine: 5.0L TPI F Code
Transmission: 5-spd Manual
Re: Help! Engine misfire under load.
Did you change the fuel pump?
I could be that with all the modifications you don't have enough fuel pressure under load.
Old May 6, 2009 | 11:23 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
Fuel pressure is 7 psi. and the pump is fairly new. The bowls are set to about 55 percent full. Doesn't seem to be sucking the bowls dry or anything.
Andrew6.688
Dec 13, 2015 10:59 AM
mdtoren
Aug 23, 2015 12:52 PM
db057
Aug 22, 2015 08:17 PM
mdtoren
Aug 16, 2015 05:45 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
