ok, I've been reading too much
Old May 8, 2009 | 01:24 PM
poomwah's Avatar
I was reading several books by David Vizard about small block chevy's and building horsepower. I had planned on using an edelbrock performer on my 350. But in his book on carbs and intakes, he showed how and where to port a cast iron quadrajet manifold. He also said that it performed better than any performance manifold he ever tested. Between this and the problems with aluminum absorbing so much heat from the engine, should I just sell the edelbrock manifold and port the stock cast iron intake?
Old May 8, 2009 | 01:31 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: ok, I've been reading too much
If you're sure your porting will equal his, and you're sure that's what you want, then go for it.
Old May 8, 2009 | 01:44 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Well that may be true but his books are what 10-15 years old? Not to knock on the value of them just that alot of things have come along way since then. Now ive read somewhere that the ede;bock performer is good for a 20 hp gain over the factory set up. How much porting would help i cant say but then again whos to say you couldnt work the performer manifold a bit as well? Ide say stick with the performer.
Old May 8, 2009 | 02:06 PM
poomwah's Avatar
damn, I just realized something.... I don't get the engine parts with the edelbrock until sunday, I guess I wasn't paying attention when i was over there. I just read that performers were squarebore, I'm going to be using a spreadbore carb :\
damn, I already told the guy I'd buy the parts, I guess I'll be selling an intake, LOL
Old May 8, 2009 | 04:53 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
There are now nearly a dozen different versions of SBC intake Edelbrock calls performer, and more than half of them accept spreadbores.
Old May 8, 2009 | 06:17 PM
poomwah's Avatar
thanks for the info atilla. I guess I'll just wait till sunday and see what I've got :]
Bubbajones_ya
Jul 6, 2024 08:32 PM
sahlomonic
Sep 20, 2015 07:15 PM
eustodp
Sep 20, 2015 05:09 PM
Rally Smith
Sep 14, 2015 06:59 PM
sandman92084
Sep 12, 2015 10:27 PM
